ANOTHER ISSUE FOR ME! *Code found*
- terrancew3
- Year and Trim: 2009 G8 GXP
So I was about to leave school and my car wouldn't turn over. The cranking sound was normal, but it wouldn't fire. So I tried multiple times, and finally it started. But it only lasted for a minute. I tried again and it ran for maybe 10 mins. I am scared to leave the lot incase of it dying again. Is this a sign of a failing fuel pimp? Or are my new plugs, wires, coils faulty? Im sick of this problem stuff.
2000 SSEi *sold 9/27/15* December '12 & May '15 COTM
2005 Grand Prix
2009 G8 GXP #418 of 1,829 November '15 TOCOTM
2005 Grand Prix
Re: ANOTHER ISSUE FOR ME! HELP!!
i would suggest putting a pressure gauge on the fuel rail and see what it reads.. my guess is a fuel pump... if that is the problem Rock Auto had a Delphi pump/sending unit (other cheaper) for like $160. and can be swapped in 30-60 min.
S
S
Shane "RedZMonte"
2004 Z16 Z06: Virgin
- terrancew3
Where do I find the pressure tester then? Autozone?
2005 Grand Prix
2005 Grand Prix
I bought one a Sears for about $30 a few years ago. It came with all of the adapters for domestic cars...very easy to use.
1993 Bonneville SLE
1988 Olds Toronado Trofeo
1985 Olds Cutlass Ciera Holiday
Past: 1988 Delta 88, 1988 98 Touring Sedan, 1992 Bonneville SE, 1993 LeSabre Custom, 2001 Aurora 3.5
- terrancew3
Found the issue. It's a faulty MAF sensor. It wasn't throwing a code, until I got it to the shop. I will buy one asap, what brand should I get? AC Delco, Cardone, Hitachi, Dorman, or Standard Motor Products are the ones offered on Rock Auto.
2005 Grand Prix
2005 Grand Prix
Re: ANOTHER ISSUE FOR ME! *Code found*
AC Delco, or get a used OEM one off a junkyard car, or from haro. The rest are junk.
- terrancew3
Thats what I figured. Is the parts direct from GM just AC Delco? Cause the guy at the shop said it was like 350 for a new one. On Rockauto is 175.00Beast wrote:AC Delco, or get a used OEM one off a junkyard car, or from haro. The rest are junk.
2005 Grand Prix
2005 Grand Prix
