Po202 code
Karloto
Year and Trim: 2002 Bonneville SLE
Po202 code
Post by Karloto »
My 2002 sle started running rough today. I went to Auto Zone and got codes p0202 and p0302. I checked cylinder #2 and found that a rodent had chewed through the wires leading to a plug above the cylinder #2. where does this wire terminate to? it looks like the front passenger side of the engine compartment. does the other end have the sort of plug arrangement or is it hard wired into something?
Re: Po202 code
We will probably needs some pictures here to help out.
But it sounds like the fuel injector connection to cylinder #2.
Karloto
Re: Po202 code
Post by Karloto »
I am almost positive it is the fuel injection connection. I am just trying to find out how to replace it.
Re: Po202 code
Take a picture so we can see what you got.
maroon111993
Year and Trim: 1997 Grand Prix GTP
Re: Po202 code
Post by maroon111993 »
:bworthless:
1997 Grand Prix GTP "Black Ice, 'cuz it's slick" - 17" Motegi Racing Rims, Hankook Optimo Performance Tires, 'Big 3' Wiring Upgrade, Weapon R Secret Weapon Intake w/ Ram Air, Larger SuperCharger lines, AutoLite 104's, U-Bend Delete, Resonator Delete, Cat Delete, Turbo Flowmaster Mufflers. 342bhp, 327 lb-ft torque, 9.091 boost psi @ 6,012 rpm.
Re: Po202 code
If its just the wires, they could be easily repaired.
If its chewed so close to the connector, you might need a different connector with a section of wiring.
