oil leak locations?
TheMannn
- Year and Trim: 2001 Pontiac Bonneville SLE
oil leak locations?
im losing oil like a quart a month maybe, it dont smoke... dont see any major leaks on top. any ideas underneath i should check?
- flatlander745
- GXP Member
Re: oil leak locations?
Look for wet spots and check the usual suspects ie: valve covers, oil pan intake etc.
Best bet is to clean everything top to bottom several times and then check it every couple days. If parking in a garage, you can put a piece of cardboard under it to help locate it.
Another common leak is the oil pressure sender located just above the oil filter.
