rear air shock hose
ramirez32385
Year and Trim: 2000 pontiac bonneville se
rear air shock hose
Post by ramirez32385 »
hello forum! have a 2000 pontiac bonneville with factory air rear shocks. i have a hose that fell from one of the shocks and fell on exhuast and got burned. it seems the hose only goes from one shock to the other shock? is that right or does the hose go in a different way?
redzmonte
Year and Trim: 2000 SSEI
Re: rear air shock hose
Post by redzmonte »
there should be a air pump under the car that connects to both shocks and inflates the air. I dont recall where they connect but they both would connect together to equilize pressure on both sides. look how the other side is ran then mirror it on the opposite side. they should have some sort of clip or retainer to keep the lines away from the exhaust or from getting pinched i would assueme
Shane "RedZMonte"
2004 Z16 Z06: Virgin
IIRC they meet at the pump, under the passenger side.
