In the last month I have noticed when making a hard right turn - main road to side road - 90 degree angle - I feel a moderate amount of resistence - no resistence making a left turn. Steering fluid is full - looks clean - does not smell burnt. Does this sound like a steering rack going bad or a ball joint , tie rod , strut, etc.
Thanks....Milty
Steering - right turn moderate resistence
- reb
- Posts like an LG3
- Year and Trim: 1997 Bonneville SE 40th Ann Edition
Original Owner - Location: Wantagh, NY
Re: Steering - right turn moderate resistence
What happens when the car is in park idling and you turn the steering wheel lock to lock ?
When the car is in park idling and I turn the steering wheel lock to lock no difference is felt in resistence.
Thanks...Milty
Thanks...Milty
- maroon111993
- Posts like an LG3
- Year and Trim: 1997 Grand Prix GTP
Mine started out this way... after a Hit n Run though but sounds like the same issue... Had to replace rack & pinion, as well as the steering pump. $1077 later, works better than newmilty wrote:In the last month I have noticed when making a hard right turn - main road to side road - 90 degree angle - I feel a moderate amount of resistence - no resistence making a left turn. Steering fluid is full - looks clean - does not smell burnt. Does this sound like a steering rack going bad or a ball joint , tie rod , strut, etc.
Thanks....Milty
1997 Grand Prix GTP "Black Ice, 'cuz it's slick" - 17" Motegi Racing Rims, Hankook Optimo Performance Tires, 'Big 3' Wiring Upgrade, Weapon R Secret Weapon Intake w/ Ram Air, Larger SuperCharger lines, AutoLite 104's, U-Bend Delete, Resonator Delete, Cat Delete, Turbo Flowmaster Mufflers. 342bhp, 327 lb-ft torque, 9.091 boost psi @ 6,012 rpm.
I was hoping it is not the rack - lots of $$$$$ - if it is I will replace it myself. Any other thoughts from club members?
Thanks....Milty
Thanks....Milty
