dashboard lights
brownbrentm
Year and Trim: 2000 Pontiac Bonneville SE
2009 Ford Escape
dashboard lights
Post by brownbrentm »
So half of my dashboard lights recently stopped working, So I can only see (at night) half of my tach nothing of the speedometer, and none of my temp or oil. Any ideas?
Fault lies with the man low enough to lay blame.
pnarron
Year and Trim: 2005 bonneville se
Re: dashboard lights
Post by pnarron »
Replace the lights, will not take that long. Had to do mine.
brownbrentm
2009 Ford Escape
how do you get to the lights wihout removing the gauges? I dont want to have to recalibrate. thanks
bc21
Year and Trim: Black 2000 SSEI and Red 2000 SSEI
Post by bc21 »
You will have to remove the needles to get to the face off of the dash. I changed my bulbs recently and had to remove them. Use a fork to lift them off, nice and easy like butter. :) There is no way around it. I took a picture of my dashboard before I started so I would replace the needles exactly where they were. You could also mark them dash with a pencil line. good luck
brownbrentm
2009 Ford Escape
so I was in a hurry last night driving a little faster than I would normally over a certain set of railroad tracks, and apparently the jolt woke the lights back up! There is only one spot on the tach that doesnt light up correctly, but I am ok with it.
redzmonte
Year and Trim: 2000 SSEI
Post by redzmonte »
usually on the cluster lights, you remove the entire gauge cluster as one unit, no recalibration needed or anything.. there are little lights that pop in the back and its done. easy to done. they twist out and they are easy to replace... here is kinda what it looks like (this is a supra cluster but same basic design):
Shane "RedZMonte"
2004 Z16 Z06: Virgin
redzmonte
Post by redzmonte »
some guys on other cars have done LED lights, they will be bright and won't burn out... plus you can change the colors up a little.. dont know if anyone here has done it but it looks pretty cool... here is a site i found looking around.. now i don't know what bulb ours take but here is an idea of what you can do.
Stock cluster with LED's:
http://store.ledoption.com/LEDoption-T5 ... on_l28.htm
custom color LED's:
Shane "RedZMonte"
