Changing front struts on 2005 Bonneville
homeboy517
- Year and Trim: 2005 SE
When changing the front struts on the 2005 Bonneville SE, can you change just the strut itself or do you have to change the entire assembly with the spring?
- DCJREDLINE
- Year and Trim: None
Re: Changing front struts on 2005 Bonneville
You have to remove the whole assembly from the car but you can just replace the strut from that assembly. Look on youtube for some visual aids.
2004 Saturn Ion 3 Quad Coupe
You will need spring compressors to safely remove the spring from the strut.
vogie01
- Posts like an L27
- Year and Trim: 2002 SLE
You could also consider replacing with an entire quick strut assembly, which is much easier to do than trying to compress the old springs. I did that instead. Here is a link to Monroe's site that explains and shows a quick strut.
http://www.monroe.com/products/Quick-St ... t-Assembly
94SilverSSEi
- Year and Trim: 97.2 40th SLE
68 w/400
94 SSEi - Location: Racine, Wisconsin
vogie01 wrote:You could also consider replacing with an entire quick strut assembly, which is much easier to do than trying to compress the old springs. I did that instead. Here is a link to Monroe's site that explains and shows a quick strut.
Not to mention swapping over the old spring can be VERY dangerous, if not done properly.
Clay
1997.2 40th SLE-138k
1999 GMC Suburban SLT-191k
2005 Escalade 253k-GINA
01bonneSC
Yes, if you have never changed a strut out before and used a proper spring compressor, I would recommend taking it to a qualified mechanic. You will need and alignment also.
Ive seen after effects of a guy getting his face smashed by spring that came out of the spring compressor(the cheap kinda you get at the parts store). Not pretty!!!!!
- DCJREDLINE
Be warned that the springs on the Monroe quick strut are heavier and your front end will prolly be higher than it should be. Just went through this with my car. Had two sets of them ordered and they both had the bigger stiffer spring on them. Ended up getting some money back and a pair of struts that I am going to put in with my old springs and mounts soon.
