96 won't idle
96 won't idle
I have a 96 Bonneville SSE that I bought for a cheap work car.
It usually won't idle and will quit when I get below a certain speed because the oil pressure drops significantly when I get to a low enough RPM. Many times I will have to shift it into neutral and start it as I'm rolling.
Any ideas?
Any ideas?
RogueSSEi
- Year and Trim: 98 Pontiac Bonneville SSEi
Re: 96 won't idle
How is the oil? full, half full, low?
Could be the oil sensor for the low pressure reading....
Could be the IAC sensor....
Could be the MAF sensor....
Could be a bad ground....
Silverjet
- Year and Trim: 1993 SSE, N/A
Re: 96 won't idle
I have the same problem with the idle, and the late ignition when i push the pedal. So late that the muffler was torn to pieces.
You have to be a psychopath to ride on an American car in Russia. I ride ...
Re: 96 won't idle
Oil is full. It doesn't leak a drop and I just changed it too. Actually it wouldn't surprise me if it was any of those sensors.RogueSSEi wrote:How is the oil? full, half full, low?
RogueSSEi
Re: 96 won't idle
A good cleaning with brake fluid for the IAC, don't spray up into the plunger spring, use specific MAF spray for the MAF, dab a little loctite (red kind) on the IAC bolts and reinstall all the sensor, hopefully this will help and eliminate A problem. If oil pressure reading is still low, refer to the tech-info section to go about replacing it, rockauto.com has them for cheap.kwc27 wrote:Oil is full. It doesn't leak a drop and I just changed it too. Actually it wouldn't surprise me if it was any of those sensors.RogueSSEi wrote:How is the oil? full, half full, low?
- renchjeep
- Posts like an LG3
- Year and Trim: 1994 Bonneville SE 240k Hot Rod
Re: 96 won't idle
I would not use red Loctite on anything I might expect to be taking apart again soon.....use blue, or wrap the threads with teflon tape.RogueSSEi wrote:A good cleaning with brake fluid for the IAC, don't spray up into the plunger spring, use specific MAF spray for the MAF, dab a little loctite (red kind) on the IAC bolts and reinstall all the sensor, hopefully this will help and eliminate A problem. If oil pressure reading is still low, refer to the tech-info section to go about replacing it, rockauto.com has them for cheap.kwc27 wrote:Oil is full. It doesn't leak a drop and I just changed it too. Actually it wouldn't surprise me if it was any of those sensors.RogueSSEi wrote:How is the oil? full, half full, low?
RogueSSEi
Re: 96 won't idle
I did with no problems, as I put the IAC on before cleaning it, let loctite set-up then remembered I didn't clean the IAC and took it off lol. I just cleaned the threads in a kerosine solution with a wire brush, good as gold. Blue or red it really doesn't matter.renchjeep wrote:I would not use red Loctite on anything I might expect to be taking apart again soon.....use blue, or wrap the threads with teflon tape.
Silverjet
Re: 96 won't idle
I have this problem and did not understand.
The scanner gave errors 18 and 42 (cam/crank error and ignition control circuit)
Power to the sensor goes fine, but I found oil on the camshaft sensor.
He's got to be dry? Also, do not stay idle at all (MAF sensor is installed a new one). Who has any idea?
- MattStrike
- Year and Trim: '99 Montana
'04 Dirtymax
'97 Camaro
Re: 96 won't idle
Assuming it's the same symptoms as the OP,Silverjet wrote:I have this problem and did not understand.
Any time I read "oil pressure drops when it idles" I cringe, and tell people to get a mechanical oiil pressure gauge and verify the actual oil pressure. 35psi at idle is normal and healthy. Less than 30 means significant bearing wear but you have time to save up for repairs, and less than 20 means failed bearing somewhere (usually).
A spun/failed rod bearing will cause low oil pressure at idle and it has enough resistance to make the engine incapable of idling.
Verify your oil pressure with a mechanical guage!!!
Boost addict
The Fleet:
'97 Camaro - Top swap
'05 STS - V8, AWD, her DD
'92 Trofeo - Fair weather DD
'99 Montana - top swap 3800
Current project:
Something cool, trust me.
Upcoming projects:
'92 Bonneville SSE
'87 LeSabre T-type
'67 LeSabre
Gone to greener pastures:
'97 LeSabre - Top swap
RIP:
'86 LeSabre - pictures
'93 SE - L67
The Fleet:
Current project:
Upcoming projects:
'92 Bonneville SSE
'87 LeSabre T-type
'67 LeSabre
RIP:
'93 SE - L67
Silverjet
Re: 96 won't idle
interesting version, and what bearing do you mean? cluster gauge shows the normal pressure.
