i need some advice
JEzze
Year and Trim: 2000 quicksilver SSEI
i need some advice
Post by JEzze »
OK my mods are listed below. My question is I am understanding that with the sc pulley smaller the better with supporting mods. With what I have what's the best pulley. I have 3.4 3.5.
I'm getting a plog really quick but for now I understand I can get more power with the bigger pulley. Can someone please explain. Thanks in advance.....
DDM tuning HID 6000k hi/lows and fogz
FWI, 180*tstate / 18 inch enkie wraped with potenza run flats , danturs tuned pcm,
Home made motor mount / autolite 605plugs/beldin performance wires. Hogan 3 inch dp w/ magnaflow hiflo cat, zzp plot and 3.4 smoothflow MpS, trans go shift kit, 10 inch gtablet mounted running torque app.
I have a kr issue please help....
yourgrandma
Year and Trim: '02 SSEi
Re: i need some advice
Post by yourgrandma »
Looks like youre in 3.6-3.5" territory with stock timing. If youre running KR free, tuning in more timing and better fueling would theoretically be more beneficial than adding boost.
JEzze
Post by JEzze »
So more fuel and timing is the trick.. I see I have speed daddy's. I have found some decent headers on eBay was wondering if it's really worth the extra hundo far headrs over plog. I also I'm getting 3* kr with 3.4, I was going to just do plog until I checked eBay headders...
yourgrandma
Headers are definately the way to go.
There are differing opinions about timing vs boost, my view is that more timing is safer and more efficient.
wake
Year and Trim: 96 olds cutlass supreme 4 door
Post by wake »
yourgrandma wrote:there are differing opinions about timing vs boost, my view is that more timing is safer and more efficient.
i agree
OP, IMO id put your headers on first, check for KR and if you have none then drop to a 3.5 pulley
3* of KR with a 3.4 pulley isnt bad but it isnt good either, ill let a gearhead explain more in detail about that!
:headbang:LUCAS Image Member # 534.
96 olds cutlass supreme SL 4 door 3100 4t60 *3.33 gears* *Fe1* 115K bone stock DD
JEzze
Post by JEzze »
Any gear head interested in lighting me on the best all around move . I have searched an searched here an GM forum there seams to be a lot of discussion. With my location and weather I just want of course the best set up and safe .
BonneMe
Post by BonneMe »
Headers definitely are better. They have better scavenging effects AND higher flow. PEM/PLog just have higher flow, still hurt the car in the upper powerband, and need a downpipe anyways to be best effective. Why not buy headers with a downpipe and be ahead...
JEzze
Post by JEzze »
Thanks for advice. I do have a hogan dp. If I was to get plog do I need to get crossover as well
yourgrandma
Get the headers, keep scanning. If I had it to do again, id probably have wrapped my headers. It does shorten their lifespan a bit, but for the price of ceramic coated togs or slps, I could rot out 3 or 4 sets of speed daddy's.
As for the pulley, on my setup, even with a big honking intercooler, I plan to keep my 3.4" and go for 18+ degrees of advance at WOT. Idea being that it will allow the pcm to pull that ecra timing if theres a problem. It also puts less paracitic drag on the engine and heats my charge air less.
JEzze
Post by JEzze »
That's interesting. So as far as the timing go how to I now what is normaland if I'm getting timing advance. It seams like the timing is all over the place. Starting at 0 when I start it and it walks it way up to hi 30 . So the higher the numeric for timing the better
EDIT * WHERE'S THE BEST PLACE TO GET THE SPEED DADDYS
You want to know the timing at Wide Open Throttle (WOT). That's really all that matters for you.
JEzze
Post by JEzze »
On my way home i will check timing at wot...
