89 Lesabre T-type resto / L67 swap
Tricked-T
Year and Trim: 1988 & 89 Buick Lesabre T-types
Re: 89 Lesabre T-type resto / L67 swap has begun
Post by Tricked-T »
I forget the brand but it's mainly due to the fact it wasnt in a down draft. Plus who knows if the temp, gun pressure and all that was right..
Tricked-T
Post by Tricked-T »
Well my T is finally home, so let the fun begin:
wake
Year and Trim: 96 olds cutlass supreme 4 door
Post by wake »
:banana: :banana:
cant wait to see the progress made :poke:
:headbang:LUCAS Image Member # 534.
96 olds cutlass supreme SL 4 door 3100 4t60 *3.33 gears* *Fe1* 115K bone stock DD
Tricked-T
Post by Tricked-T »
Hi res images
Hood:
The clean interior:
The side:
The molded spoiler:
The Clean under side:
To album
http://s139.photobucket.com/albums/q318/BuickT88/
Tricked-T
Post by Tricked-T »
I know it has been a long time since I have posted any updates, but between work and this car I have had my hands full. For those of you who are interested here is a photo update of the things I have done in the past months. Getting close to getting a rolling chassis back which means almost time for motor install.
Thats it for now. More to come soon.
95naSTA
Post by 95naSTA »
I'm completely jealous of your rear undercarriage.
Tricked-T
Post by Tricked-T »
Thanks, It is a very clean rust wise, but it was very dirt so it took a while. I basically undercoated where there was existing undercoat and along the rails to be uniform. The rest is just cleaned. Once it is fully done and I can get it on a lift I snap a shot of the entire underside.
Tricked-T
Post by Tricked-T »
Update
J Wikoff
Year and Trim: 1992 SSE
Post by J Wikoff »
Cleanest tank ever.
1oldman
Post by 1oldman »
any bicycle sitting that close to a work in progress as yours makes me extremely nervous. Looking good! - BC
Tricked-T
Post by Tricked-T »
So I am finally getting back to my T and this site! It has been some time since I have done any work to it. Life kinda got hectic and it had to be put on hold. Currnetly balancing time and $$ between the T, fixing my bike from the wreck, and my daily Lincoln LS.
Anyway this is this weekends project:
Wire in fuel pump, and install gas tank and filler.
Install A-arms, rear sway, rear struts and springs.
I am still figuring out the rear disc conversions (hoping George gets back to me)
Current hiccup is that I have seemed to mis place the large nuts that bolt the strut to the strut mount, anyone have any laying around I could get?
I hope to have more frequent updates soon.
Tricked-T
Post by Tricked-T »
I got a little more done this evening on the T. I finished wiring in the new weatherpack connectors so that I can run the grand national fuel pump hot wire kit. I also got the pump all assembled and put in the tank and the tank is ready to install tomorrow. I hope to have the tank and lower control arms and possibly the struts all installed tomorrow. Here are some pics from this evening:
Taking apart the weather packs:
Merging the grounds:
and now on the body side harness:
done:
pump ready to go:
All Done:
