03 Bonneville SSEI
- zvega88
- Year and Trim: 2003 Pontiac Bonneville SSEI
03 Bonneville SSEI
So my bonneville ssei is giving me this weird problem. In the morning when i start the car and i put it in reverse it kinda takes few seconds to change gears from parking to reverse. I notice that if i go on reverse and i press the gas it takes few seconds and then it kicks in reverse. Sometimes it changes gears really strong but it runs normal. Why is the car taken few seconds changing gears and why sometimes when changes gear kicks really hard the engine?
[b]THE KNIGHT RIDER[/b]
- jmal843
- Year and Trim: 2001 Pontiac Bonneville SSEI
Re: 03 Bonneville SSEI
How many miles are on the car? How is/has it been driven? You definitely do not want to wait too long to have that checked because any delay when putting a vehicle in gear is not the best sign in the world. IJS
I had a problem like this twice. First it was my transmission but after the delays it went out while in route to class and I was fortunate to be within the warranty so it was replaced at no charge. The second time was 2 months later my torque converter went bad. Would start, delay after putting in gear, sometimes it would kick, and then it just didn't move. Its possible it could have been the same torque converter
Hopefully someone will be able to confirm though, but your symptoms sound very familar and you may want to stop in at a transmission shop.
jMal843
01 SSEi
20% Tint/Yellow Fog light Tint/clear headlights/60 SMD Xenon SwitchBack TurnSignal/SSS Ultra H&L Beam/SH Fog/clear tails w/Amber LED Signals/SSS Reverse Bulbs/Autolite 605 Plugs/180 t-stat/Power Stop C/D Front Rotors/EBC Ultimax Slotted Rear Rotors/EBC Red Stuff Pads/Intense FWI/MagnaFlow Hi Flow Cat
Standing By-Aeroforce Interceptor Scan Gauge/Tuned PCM/3" Stainless Steel Downpipe/Plog/Resonator Delete/Dual Slant Tips
01 SSEi
What is the condition of the fluid (color, smell burnt)? Do you know if it has ever had the filter replaced?
- zvega88
The car has 114000 miles. And i have been driven. Its been giving me that problem about 2 months now.
I would definalty start with a Fuild drin and replace the filter/fluid. and go from there.
Shane "RedZMonte"
2004 Z16 Z06: Virgin
ray364
- LE Member
- Year and Trim: pontiac bonneville 2002 ssei
must likely a clog filter! is a common problem with any automatic tranny
