Heater Inlet Adapter/Flow Restrictor/Check Valve
pojawis
Year and Trim: 2001 SSEi
Post by pojawis »
Anyone have a part number or part source for this? It's the metal adapter that fits into the heater hose and then into the alternator/tensioner bracket. I've been searching around this forum and found the proper name(s) for it. Also found a diagram on the Brunswick GM site. They had the parts on the diagram, but no part numbers.
Mine are leaking a bit. I think all I'll need are the o-rings, but want to be prepared.
Thanks.
Re: Heater Inlet Adapter/Flow Restrictor/Check Valve
I have had mine off a few times and they are still fine. Most likely the o-rings are bad. I have no idea what the part number is, but I am sure Andrew (harofreak00) would have some. The problem is: viewtopic.php?f=2&t=30370
pojawis
Post by pojawis »
Appreciate the reply.
In my search, I saw the Honeymoon notice.
I'm expecting to replace the o-rings and not the adapters. We'll see what shape they're in when I pull them.
