my car just shuts off for no reason. well some reason
my 98 bonneville se will shut off while driving for some reason. after coasting to a stop you can turn the key on and when you hear the fuel pump come on and prime you can crank it and drive on. sometimes it may take turning the key 10 20 times until you hear the full pump before it will crank. i have changed the fuel filter thinking it may be stopped up and it still has the problem. there was a time that i was powering the window up when the car died and the window lossed power also, but then begain to roll up again. can someone tell me anything about this problem. any help would be nice... thank you............................
- J Wikoff
- Year and Trim: 1992 SSE
Re: my car just shuts off for no reason. well some reason
Unhook your battery, clean any corrosion from the ends (peel back the rubber covers and clean in there too), then retighten them (don't over do it, they can strip out), and try again.
- Mechanical Mike
- Retired Gearhead
- Year and Trim: 99 SSEi
99.999 percent chance it's a corroded ground bus on the driver's side.
2006 Chevy Monte Carlo SS
- 88bonnsse
- Posts like a Northstar
- Year and Trim: 1988 sse - 80,000 on the clock and my first car...
1995 se wit da sle package- 120,000 on the clock and ticking stronger then ever... - Location: allentown pa
my 88 bonneville had the same symptoms you are getting and my problem was a bad torque converter clutch in the transmission. all i did was unplug and the car stayed running fine. gave me less gas millage but atleast the car stood running
- willwren
- Retired Admin
88, that isn't going to work on any car 92 or newer. That's not a fix, either.
Chances are near 100% that it's the driver or passenger side ground bus, or the battery cables themselves. Go after all 3.
donaldtfreeman
- LE Member
- Year and Trim: 1999 Pontiac Bonneville SE
My car has been sitting up for several months while I've been out of state on a job. When I got home the other day, the car would crank & run for just a few seconds and then die. I figured plugged fuel filter because fuel pressure didn't seem high enough. That didn't help. That's when I noticed that power windows wouldn't work and the power seat would just click. I checked the cables, battery and grounding, and everything checked out OK. That's when I came across this forum and discovered there's a grounding buss by the driver's door. It took less than 10 minutes to access it, clean the corrosion off and replace the trim. Everything's working OK now.
My thanks to you guys for identifying this problem and easy fix!
Terry
Terry
frankdux420
- LE Member
- Year and Trim: 1997 se
never mind wrong spot
- Bugsi
Holy thread necrophilia, Batman!
Don't raise someone else's old thread from the grave to ask about your own car's new problem.
Please start a new thread with your car's problem.
`05 Mercedes S500
`05 Mercedes S500
