Oil Seeping/AT-205 Re-Seal
Gagger14
Year and Trim: 2010 Dodge Ram SLT Big Horn
1995 Chevy Camaro Z28
Post by Gagger14 »
Hey guys, i'm in a real predicament... Just found out my '04 GXP is losing oil through the exhaust and I'm not real sure what I wanna do. The seep is pretty slow (for now) as it took about 6k miles using mobil 1 high mileage synthetic oil for me to find out that it is indeed disappearing. I know its very expensive to fix oil leaks in these N*, money which I dont really have right now, and i've been told by a few knowledgeable ppl that I should trade it in before it gets bad. Problem is, I really like this car. Talked to my mechanic and he recommended trying AT-205 re-seal. Have any of you used this stuff before? Did it work? I can use any advice or knowledge on the topic as I would like to figure out my options.
Thanks for the help.
In My Garage:
1995 Camaro Z28 - LT1 w/ 6-speed, Magnaflow Exhaust, Moroso Cold Air Inake, Powerstop drilled/slotted rotors and ceramic pads, Z06 Chrome Wheels, Founders Performance Strut Tower Brace (Work in Progress)
2010 Dodge Ram SLT Big Horn Edition Quad Cab - 5.7L Hemi, 390HP, 4x4, Daily Driver
Past Vehicles:
1989 Acura Legend - 'Tank'
1999 Dodge Dakota Ext. Cab - 'Bulldog'
2004 Bonneville GXP - 'Red Demon' - Already Missed
***Showed up expecting a battle, left with a laugh***
94SilverSSEi
Year and Trim: 97.2 40th SLE
68 w/400
94 SSEi
Re: Oil Seeping/AT-205 Re-Seal
Post by 94SilverSSEi »
Personally from what I have read/heard. I would not put any "sealers" in the engine as they just good up the engine and CAN cause oil passage blockages and other problems. Not saying that will happen but it's a possibility.
Not sure exactly about the stuff you are talking about though.
How many miles on your car?
Clay
1997.2 40th SLE-138k
1999 GMC Suburban SLT-191k
2005 Escalade 253k-GINA
Gagger14
Post by Gagger14 »
94SilverSSEi wrote:Personally from what I have read/heard. I would not put any "sealers" in the engine as they just good up the engine and CAN cause oil passage blockages and other problems. Not saying that will happen but it's a possibility.
I got just over 83k on the car. Everything else seems fine, only reason I know I'm losing oil is because the DIC warning light came on and when I checked it, it was down to close to 2 quarts. Not sure if its worth keeping and repairing or trading it in.
In My Garage:
Past Vehicles:
How do you know you're losing it through the exhaust?
It can only get into the cylinders and exhaust through either bad rings, a bad valve seal(s), or leaking in through the intake, which is highly unlikely.
repinS
Moderator
Moderator
Year and Trim: 09 G8 GT
Post by repinS »
^ Or carbon buildup, or no problem at all.
Some people's Northstars are known to consume oil and this is NORMAL. It is an engine with performance put in mind and many perfectly healthy motors will do it for many miles without issue. Another problem here is that you haven't checked your oil level for 6,000 miles? I would expect many cars to be down at least a quart at this point and still be normal. Mine doesn't really consume at this rate, but I definitely find myself occasionally topping up a bit towards the end of my change interval (5k miles).
Is your engine normal? I don't know. But it could very well be.
dpnewfie
Post by dpnewfie »
No matter how well maintained, these engines will leak and consume oil. I've replaced the vc gaskets, main seal and oil cooler lines, yet I still lose up to a quart every 6-8k.
You have a lot of life left in that motor so don't be too worried about oil loss. Just do a check of the oil level every fill up and top up accordingly.
Cheers.
J Wikoff wrote:It has been an honor and privilage to have been serviced by you.
2005 Bonneville GXP, 200k and SOLD!
Gagger14
Post by Gagger14 »
Thanks a lot for the advice guys. After doing some research on my own and talking to both a caddy and Pontiac/GMC/Buick dealership, I came to the realization and a better understanding of all the things you guys brought to my attention. I didn't realize that the N* was "engineered" to have some oil consumption and that it is completely normal. I also didn't know that this engine performed better with conventional oil. I currently have Mobil 1 high mileage synthetic oil in it (hence the 6k miles before my last oil change), but I think from now on, I'll be using just conventional oil and changing it around every 3k.
Thanks again for the help guys. I'm looking forward to driving my GXP for many, many more miles.
In My Garage:
Past Vehicles:
Gagger14
Post by Gagger14 »
And while on the topic, a pretty interesting read:
http://www.cadillacforums.com/forums/no ... usage.html
Thought this gave a pretty good explanation and may help others in the future.
In My Garage:
Past Vehicles:
repinS
Moderator
Moderator
Post by repinS »
Great thread there.
Though, I run synthetic myself and have seen no issues in the year and 20,000 miles that I've owned the car.
dpnewfie
Post by dpnewfie »
I've run synthetic for the past 115k miles and have had no issues.
yonkerse
Post by yonkerse »
From my understanding, the only reason Synthetic tends to be consumed (or leak) quicker is because the molecules are smaller in size, allowing them to seep though tight spaces that the larger conventional molecules wouldn't make it though...
Eric
2005 SLE, Greystone Metallic, 152K.
A few mods..
I put 8 quarts in and run 6k-8k changes in our GXP and don't burn enough per change to justify a top-off (>1 qt.).
repinS
Moderator
Moderator
Post by repinS »
Mine doesn't get topped off either. Oil level does go down, but never worse than me adding half a quart in because I'm OCD. From the Cadillac Forums thread, it is important not to overfill when changing.
But, everyone's mileage will vary. Some may burn a quart per 1500 miles, some a quart per 3000, and so on.
Loopy
Year and Trim: 2004 GXP
Post by Loopy »
So how often should these engines have their oil changed.
dpnewfie
Post by dpnewfie »
Loopy wrote:So how often should these engines have their oil changed.
As often as any other engine. 3-5k on conventional and 6-8k on synthetic. Of course, others may feel diferently.
repinS
Moderator
Moderator
Post by repinS »
The official answer from GM is to follow your Oil Life Monitor in your DIC.
I do 5000 miles on synthetic. I follow more extreme schedules than most because I do a lot of dense urban city driving with lots of stop and go. It usually works out to an indicated 50% on the Oil Life Monitor, but I ignore it.
If you followed your Oil Life Monitor you'd go 10k on a change, no matter the oil....
I go 7500 on our cars, based on 90% highway miles.
Gagger14
Post by Gagger14 »
repinS wrote:Mine doesn't get topped off either. Oil level does go down, but never worse than me adding half a quart in because I'm OCD. From the Cadillac Forums thread, it is important not to overfill when changing.
The ironic thing for me is how this all started for me because of my DIC and "low oil" warning. If that hadn't gone off, I would have no idea I'm even consuming oil as my N* sounds amazing, shows no leaks, and definitely isn't lacking in the performance department. It is nice hearing everyone's different experiences on the topic though, and it still amazing me how different each of these N*s can be. Even as much as I like using synthetic oil, I just figured I would see what kind of difference conventional oil would make since i had 2 mechanics recommend it for these engines. I'll try to remember and let you know what I find out.
I want to thank you guys again for the help. Chalk that one up for the "peace of mind" department as I really enjoy my GXP. Now for updating my rear 6x9s... :beerchug:
In My Garage:
Past Vehicles:
CMNTMXR57
Post by CMNTMXR57 »
Every internal combustion engine on the planet consumes oil. Some more, some less. Even your lawn mower. If you haven't checked it in 6k, well yea, I would expect some form of consumption. EGR systems and PCV systems can sometime compound things. Go on to any of the LSx forums for the LSx motor, and look at how many people run catch-cans for the amount of oil those motors push back up and through the intake. The LS2 motor is really notorius.
Daily Drivers:
2011 Camaro SS
zigger21
Year and Trim: 1997 Bonneville SSE
2005 Bonneville GPX
Post by zigger21 »
Gagger14 wrote:Hey guys, i'm in a real predicament... Just found out my '04 GXP is losing oil through the exhaust and I'm not real sure what I wanna do. The seep is pretty slow (for now) as it took about 6k miles using mobil 1 high mileage synthetic oil for me to find out that it is indeed disappearing. I know its very expensive to fix oil leaks in these N*, money which I dont really have right now, and i've been told by a few knowledgeable ppl that I should trade it in before it gets bad. Problem is, I really like this car. Talked to my mechanic and he recommended trying AT-205 re-seal. Have any of you used this stuff before? Did it work? I can use any advice or knowledge on the topic as I would like to figure out my options.
I have the same problem! I have a 2005 Bonneville GXP and it should not be using oil. I have no clue where the oil is going. Its not leaking any oil because I dont see abut I have to add neanything on my spotless garage floor. Any halp, its not leaking into the other fluids because it doesnt show up on any other levels. I am very confused, I also wiped my hand on the inside of the muffler I there is no signs of oil, it had a little carbon built up in the tail pipe but nothing alarming
