I am having the same issue only the opposite. Archon I was going to make a post about this issue.
Recently i had the issue were the back windows don't go down and locks don't work. So when I pulled the seat out and carpet up to get to the wire harness. When I was going through the wire harness i had found a similar connector that was slightly rusted. Thinking this was the connector point for the back window problem i cut it and rewired it. Realizing after I was done that the windows were still not working i went deeper and found the correct one. So I wasn't real sure of what the 1st wire I worked on was for. now that the car is back together and I started driving it I noticed that I cannot get air out of the vents.
The ? I have is do you know if there is wiring for the actuator that would run under the seat and to the rear of the car maybe to the fuse box. I would believe there would be but, more for the entire assembly not just the one actuator motor the controls the direction of the air.
If there is wireing that runs back for the actuator;
I thought that maybe since these cars are prone for water leaks that maybe his wire rotted and it is causing non function problem.
If its not: then I may need some help too.
