Busted Header
crush
Year and Trim: 1992 SSEi
Busted Header
Post by crush »
:sad5: Down pipe broke off my SSEi on the highway yesterday. I have a spear on SE need to figure out how to swap them. looks like an engine pull to me. Also is their anything I can do to make them flow better while I have them off.
CrusH
bonnevillain
Re: Busted Header
Post by bonnevillain »
it broke off? O.o
GoldenBullet
Year and Trim: 2001 GMC Yukon XL
Re: Busted Header
Post by GoldenBullet »
wow, pics?
-Matt
crush
Re: Busted Header
Post by crush »
don't know how, that really concerns me. I'm hoping clogged cat and bad weld. It was acting stopped up sense I got it 4 months ago. Started sounding like it was getting a exhaust leak 2 weeks ago and the boost gage started act weird (jumpy and seemed to run higher than usual also) then too. Camera is busted too, I plan on getting new one SOON!!!
CrusH
BillBoost37
Year and Trim: 00 Regal
Re: Busted Header
Post by BillBoost37 »
The downpipes and or manifolds can be swapped w/o pulling the engine. Opening up flow on the DP usually reduces torque.
97 Ei
97 GS
98 GS
willwren
Re: Busted Header
Post by willwren »
Don't increase the downpipe diameter on a 92 SSEi. Use a stock part.
You can remove the manifold to the driver's side as long as you pull the downpipe studs out of the flange first.
crush
Re: Busted Header
Post by crush »
Thanks, just got home from work, and thats some great news not having to pull the motor :banana: . Is there anything major in my way on driver side? Now I need to go look at what I'm getting into again.
CrusH
crush
Re: Busted Header
Post by crush »
got her back together and running, but she running rough. got to check that out tomorrow.
CrusH
