93 skylark
93bonnevillese
Year and Trim: 1993bonneville se
93 skylark
Post by 93bonnevillese »
my brothers 93 skylark has not been ideling right i drove it had hetold me it idels low and when he puts it in n it idels even worse than in drive help me please the car has 207,000 miles
1993 Pontiac Boneville Se 3.8L V6 My car mods to come new blue head light bulbs alloy wheels done
1993 Buick skylark 4 dr custom 3.3l V6 brothers
1996 Chevy corsica 4dr 2.4 4cyl
1998 Mercury villiger Totaled at 150,000 miles
1990 Buick Century Totaled at 300,000 miles
1991 Chevy lumima Totaled at 399,999 miles
2008Chevy malibu Ls 3.5L V6 114,000 miles
J Wikoff
Year and Trim: 1992 SSE
Re: 93 skylark
Post by J Wikoff »
First thing I would do is look for vacuum hoses that are disconnected or falling apart and listen for hissing. Vacuum leaks can cause bad idle. You could also spray around gaskets and vacuum lines with TB cleaner. If the idle changes when you spray a specific spot, there's a leak there.
I would also clean the MAF. Using q-tips dipped in rubbing alcohol, gently run the tip across the sensor filaments.
