Rebuild On L67??? anyone??
shredthebonnie
Post by shredthebonnie »
Looking for a couple pointers and maybe some personal experience or other problems anyone has encounter while replacing UIM, LIM, and possiblly head gaskets. car has just under 200k. basicaly im pretty sure these need replaced. car was leaking air and antifreeze out the injector seals. any help would be appriciated. even if its something as small as little tricks to make things easier.
thanks so much.
2000 Bonnie SSEi, New FR lower control arm, FR out tie rod end, Rear struts, Rear upper alignment arms (for confused names for these things), New tires, battery, mid-pipe, catylitic converter, and a freshly rebuilt top end. ALL ADDS UP TO MONEY>>
01bonneSC
Year and Trim: 05 Chevy 'Hoe
89 SkiDoo
Re: Rebuild On L67??? anyone??
Post by 01bonneSC »
Head gaskets never ever need replacing unless blown, which ive never heard of happening on 3800s. Make sure you get the aluminum LIM gaskets. Also there is no UIM gaskets on the L67, you have a supercharger instead.
Techinfo is your friend...read it twice before you start.
http://www.pontiacbonnevilleclub.com/fo ... =53&t=3591
Bag up and mark all your bolts, makes it easier later.
Your UIM is your supercharger, you don't need to replace it. The supercharger gasket is called the plenum gasket at most parts stores, you'll need one.
