Paint sealant or wax?
- SSEiMan01
03 PAU - Location: DeKalb, IL
I am wondering about some things I have heard regarding sealants vs. waxes.
I know a good bit about detailing, but this is one thing I am unsure of.
I have heard that Sealant should be used INSTEAD of wax and that if you wax on top of sealant (like I do), that it will render the sealant "ineffective" so to speak. And that because sealant can tolerate more heat, hence protecting the paint more (?), wax should not be used on paint that has a sealant on it.
For the record when I wax, every other wax I use sealant. Anytime I do a detail for someone, I usually do Clay bar, Compound, Swirl remover, Glaze or polish, Sealant, and then wax. Based on this chart; http://lib.store.yahoo.net/lib/autogeek/flowchart.jpg
I am basically asking, Should sealant be used INSTEAD of wax, or is using sealant and then following that with a coat of wax a good idea?
James May wrote:Hello.
01bonneSC
Re: Paint sealant or wax?
Your chart says you can use both.
- SSEiMan01
Yes, but the information I heard was from a person who does work on restoring paint not just repainting, and was wondering if anybody has heard anything one way or the other.
Sealant lasts longer than wax. Hence it creates a good base that you can wax over for a while. Sealant then wax will work fine.
- SSEiMan01
Glad to know I haven't been doing something wrong,in terms of the paint on my car anyway
95SLE
- Posts like a Northstar
- Year and Trim: 2004SLE
Wax over sealant is the best of both worlds.
What products are you using?
2004 SLE Crimson Tintcoat with Dark Pewter Interior. Mods so far: Wood Dash Kit-Window Tint-CATZ Fog/Driving Lights
Custom Fabricated Stainless Steel Mesh Grill-Painted Calipers-3rd Brake Light Decal-Strut Tower Brace.INTENSE™ Level 1 L36/L26 Performance Package, Intense Shift Kit. ZZP ER Rockers and a HV3. L76 springs
COTM April 2007
LeSabre in Buffalo
- Year and Trim: 2012 Eco
Yes, put the wax over a sealant. They're complimentary, not mutually exclusive.
- wake
Will listen to Tom (95SLE) he knows his stuff..i made this for him about a year ago
- SSEiMan01
I use Meguiars ULTIMATE products and if necessary, I am also a fan of the Professional Meguiars line.
As for wax, on my own cars I use Pinnacle Souveran, Liquid or paste depending on colour. Anything else, with some exceptions, gets Ultimate liquid or paste.
Wake, I like that picture... nice work
95SLE
Will:SSEiMan01 wrote:I use Meguiars ULTIMATE products and if necessary, I am also a fan of the Professional Meguiars line.
You should try Fuzion as a winter wax. Apply 2 coats 24 hours apart for a nice finish that will last you all winter. Then go back to the Souveran in the spring/summer.
I had been using liquid Souveran on light colors and picked up a tub of paste Souveran earlier this spring. I am very happy with the Souveran on dark colors.
COTM April 2007
- LeSabreUltra
- Year and Trim: 2012 Nissan Maxima SV Premium
Definitely use both! I used Liquid Glass (sealant) under Meguiars NXT (wax) and the result was great, hid a lot of surface imperfections and added a deep shine.
-Dan
_
_
__I n n o v a t i o n__T h a t __E x c i t e s
_
_
