water
Talk about the other 3800 powered GM cars, particularly for items not covered in other sections that may be unique to your year/model, and differ from a Bonneville.
turkeykiller
Year and Trim: 1996 SSEi
2009 Saturn Astra XE
1999 grandprix se
water
Post by turkeykiller »
On my 99 grand prix se 3.8, I had water coming in on the passenger side. LOTS OF WATER. enough to have a goldfish swimming around.
I instalded a black plastic gutter that my GM dealer sold me. Its placed over the cabin filter.
That fixed the problem from getting rain water in.
But everytime I use my A/C, water drips into the fan and then on the floor of the passenger side
PLEASE HELP ME
I have already replaced 2 restance and 1 fan. My wife is tired of getting her feet wet.
It can be done, it will be done, it should be done, it shall be done...tomorrow
PONTIAC BONNEVILLE SSEi 1996 gutted air box 180 deg
PONTIAC BONNEVILLE SE 40th 1997 RIP(parts car)
SATURN ASTRA XE 2009
turkeykiller
1999 grandprix se
Re: water
my airbag light is on could there be a link
turkeykiller wrote:On my 99 grand prix se 3.8, I had water coming in on the passenger side. LOTS OF WATER. enough to have a goldfish swimming around.
PLEASE HELP ME
wdean
Year and Trim: 2001 Galaxy Silver SSEi
Re: water
Post by wdean »
Not sure if the water problem would cause the air bag light to come on, but I tend to think not. There should be a rubber drain on the passenger side of the bulkhead where it curves down to meet the floorpan (on the outside) check to see if that is blocked. It should have a duckbill kind of end that stops water getting in, but allows water to drain out.
____________
Wayne
turkeykiller
1999 grandprix se
Re: water
thanks Ill check that. on the passengerside under the seat there seem to be a little square box could that be the airbag modual?
wdean wrote:Not sure if the water problem would cause the air bag light to come on, but I tend to think not. There should be a rubber drain on the passenger side of the bulkhead where it curves down to meet the floorpan (on the outside) check to see if that is blocked. It should have a duckbill kind of end that stops water getting in, but allows water to drain out.
Re: water
The water could cause the airbag light.
I am not familiar with the Grand Prix, but you may want to remove the interior and do a lot of drying. On the bonnevilles, there are several grounds throughout the chassis and the airbag module is under the seat.
As for the water leaking in, it sounds like the drain for the ac condenser is plugged.
turkeykiller
1999 grandprix se
Re: water
thanks
