Posted this in the GXP section at first, by mistake.
The air blowing out of the vents only gets around 70 degrees(the dial is on the coldest setting), and there is a full charge of refrigerent in
the lines. Any ideas on what could be wrong? thanks
A/C problem
- AJT2004
- Posts like an LG3
- Year and Trim: 2004 Bonneville SE
A/C problem
- In_da_boondocks
- GXP Member
- Year and Trim: '05 Impala SS
Re: A/C problem
Excuse the dumb question, but does the compressor properly cycle?
05 Impala SS: INTENSE FWI - INTENSE 180* t-stat - Autolite 104 plugs
1fatcat wrote:There are only two things I like to see in a bra, and a car is NOT one of them.
imidazol97
Re: A/C problem
Let me ask:
Was the compressor engaged and the system running with the blower on HIGH?
How did you measure the pressures? Gauges?
I use an InterDynamics gauge that goes from can to can I bought at Walmart. The good range is 25 to 40 PSI on the low side. I measure that as I fill by running the engine above idle, a fan blowing on the condenser in front of the car like it was going along at 20 mph or so.
But not seeing the high side pressure is like feeling an elephant in the dark.
I do know the factory service manuals say that after running and coming to equilibrium the metal tube leaving the evaporator at the firewall should be colder than the ingoing tube.
You don't mention what conditions you were in while getting the 70 deg out. What was the outside temp? How fast is the engine running?
- AJT2004
- Posts like an LG3
Re: A/C problem
Yes the compressor was on, and i was using the gauge that i fill the lines with refrigerent.
Yes it was hot outside(prob 92 degrees), even with the fans on recirculate the air will never get cold. thanks for the response
