Front end shimmy due to wheel manufacturing defects
torero500
Year and Trim: 2000 SE 118k miles
Post by torero500 »
With the notorious 65-75 front end shimmy with this 2000-2005 car, I'm wondering if one cause is basic manufacturing loose tolerances resulting in unbalanced wheels/not round wheels, for the stock wheels used for the Bonnevilles. Heaven knows everything under the sun has been tried on the suspension parts, with very spotty results. If you have or have had the front end shimmy, has anyone just simply replaced the wheels with aftermarket wheels, with new tires with a good balancing job and front end alignment, and that resulted in absolutely no improvement in the shimmy?
02ssei
Year and Trim: 2002 pontiac bonneville ssei
Re: Front end shimmy due to wheel manufacturing defects
Post by 02ssei »
When I bought my car it had afrermarket rims on it. I rotated the tires thinking that would help and it did not. So, I went and found another ssei that had no shimmy. Took the rims and tires off it and put them on my car, still had the shimmy. I personally think its in the transmission. But I wont know for sure until I have it rebuilt later this year.
Good luck.
2002 Bonneville SSEI 170K
"Three men walking always has one teacher."
There's a reason we balance wheels and tires, because they aren't perfectly round or weighted. They have to meet a certain spec to get on the car, and unless you run over a curb or somehow bend one, that really isn't going to change. If you want to eliminate your wheels and tires completely from the shimmy, have them road-force balanced.
golfyeti
Every available option
Post by golfyeti »
torero500 wrote: If you have or have had the front end shimmy, has anyone just simply replaced the wheels with aftermarket wheels, with new tires with a good balancing job and front end alignment, and that resulted in absolutely no improvement in the shimmy?
Yep I have, my brand new after-market wheels and tires (shown below) did not change the shimmey one bit. Had my swoopies and RSA balanced many times, including RoadForce balanced too. No change. Changed all bushings, control arms and hubs. Have not changed CVs or front struts.
I get the shimmey say between 62 -65 mph into a headwind but turn around and I only find the shimmey range between 65-71 with a tailwind. This has been verified many times.
No matter how much faster you go the shimmey does not re-emerge as I would expect from unbalanced tires.
It's matter of a certain "play in torque resistance" at cruising speed.
Question: Does the CV joint or drive shaft have a torquable rubber compenent (I'm thinking like a worn u-joint on a rear wheel drive)? One who's torque resistance might fluctuate at a certain medium-low torque level like that found at a certain (wind resistance) hwy cruising speed? I hope you get the drift of what I am asking.
The only observance I had that may contradict the above theory is that if you go into Neutral at say 75 mph and coast down through the shimmey zone speeds the shimmey will occur (drivetrain disengaged).
Last guess, worn or bent drive shaft?
Mark
The Familyman's Trans-Am
2003BlackSapphireSLE
Year and Trim: 2003 Pontiac Bonneville SLE
Post by 2003BlackSapphireSLE »
i was without shimmy for a good long time, however it has returned just not as bad. funny as how the front and rear trans mount are bad again! im thinking a correlation between the two.
2003 Pontiac Bonneville SLE - Sylvania Silverstar Fog lights, 5000k HID conversion low beams, Disabled DRL, cranking headlight delay kit, GXP style exhaust tips, solid front mount. Approx. 86k miles and still kickin strong!
golfyeti
Post by golfyeti »
2003BlackSaphire,
try this where you won't get a speeding ticket...
If this occurs for you too then this eliminates motor mounts as the drive train is not engage.
So my question now is, other than wheels, what is still rotating while in neutral?
Or is this perhaps an aerodynamic issue, which was my very first suspicion, bad air dam design or bad aerodynamics of the wheel well or the coke bottle body design of the 2000+ style. If I replace the CV and struts and the shimmey is still there then I'm chocking it up to bad aerodynamics at 63-69 mph.
Mark
torero500
Post by torero500 »
My car will shimmy with car in neutral at 75 mph.
Lots of parts inside the trans are still spinning in neutral, it's just that the gears aren't engaged with the input shaft.
torero500
Post by torero500 »
Update: Finally broke down and bought 4 new tires last weekend at discount tire. The cheapies, $86 Falken label from cooper tires. Around town no more front end vibration, softer ride, and at quite fast highway speeds just the 4 new tires eliminated about 95% of the total front end vibration I used to get at 55-75. There's still a tiny bit in the passenger's seat, but the steering and dash now have dramatically less shimmy. There are actually long patches of complete vibration free driving. About the only other front end suspension work I've done on the car is new rotors and brake pads, and new inner tie rods.
So in conclusion, putting new tires on, among the most obvious of solutions, can work.
goochman
Year and Trim: 2002 Bonneville SLE
Post by goochman »
torero500 wrote:Update: Finally broke down and bought 4 new tires last weekend at discount tire. The cheapies, $86 Falken label from cooper tires. Around town no more front end vibration, softer ride, and at quite fast highway speeds just the 4 new tires eliminated about 95% of the total front end vibration I used to get at 55-75. There's still a tiny bit in the passenger's seat, but the steering and dash now have dramatically less shimmy. There are actually long patches of complete vibration free driving. About the only other front end suspension work I've done on the car is new rotors and brake pads, and new inner tie rods.
I had a horrible virbation also - it was time for new tires and after I got 4 new tires, alignment, balance I had the same result - 99% of vibration gone at 55-75 and most times no vibration.
alexcoqui
Year and Trim: 2001 Blue SLE - 2001 Black SSEI - 2005 Grey Aztek
Post by alexcoqui »
My vibration stoped when I fixed my transmission.
2001 Blue SLE - 1995 Black SSE - 1988 Black GTA
