ABS issue-update
- In_da_boondocks
- GXP Member
- Year and Trim: '05 Impala SS
ABS issue-update
Yesterday I noticed that my traction control message has started coming on while driving on surfaces it should not be necessary. When this happens, it is accompanied by an odd "buzzing" sound (that's the only way I can think of to describe it). It only seems to happen while accelerating through a corner from a stop. Any ideas what's going on or what I should be watching for?
Edit: It has only happened a few times so far. There are no warning lights present.
Last edited by In_da_boondocks on Sat Mar 05, 2011 1:55 am, edited 3 times in total.
05 Impala SS: INTENSE FWI - INTENSE 180* t-stat - Autolite 104 plugs
1fatcat wrote:There are only two things I like to see in a bra, and a car is NOT one of them.
Re: ABS issue?
That buzzing is your ABS activating. You probably have the common problem of a bad wheel speed sensor or wiring. It will only get worse until you get it fixed.
- In_da_boondocks
- GXP Member
Re: ABS issue?
If that's the case, why doesn't it disable the ABS?
Re: ABS issue?
It hasn't failed yet. It's just reading incorrectly, making the ABS think it needs to actuate.
- In_da_boondocks
- GXP Member
Re: ABS issue?
Oh ok. So all there is to do right now is wait until it gets worse so I can see which one is bad?
Re: ABS issue?
Or you could scan it with a Snap-On or Tech II and see which one is bad.
- In_da_boondocks
- GXP Member
Re: ABS issue?
Ok thanks. Maybe if I'm ambitious some day I'll run over to the auto shop at school and let them guys scan it. I don't have access to a scanner.
- In_da_boondocks
- GXP Member
Re: ABS issue-update
Since about the middle of December, my traction control system and ABS has been disabling itself every so often while driving. I had a Tech II hooked up to it a while ago and hooked up a code reader today. Both times, no codes were present. Any ideas?
You weren't using the Tech2 correctly. If your TRAC and ABS lights were on, I guarantee you have a code(s).
A code reader won't pick up ABS codes unless it is designed to.
- In_da_boondocks
- GXP Member
I should have stated that it wasn't me using the Tech II, but an automotive instructor at the tech college I go to. I would hope he knows how to use it.
Edit: He said the only thing the Tech II told him was that I recently had excessive wheel spin.
Last edited by In_da_boondocks on Sat Mar 05, 2011 4:03 pm, edited 1 time in total.
That last comment really makes it sound like he doesn't know what he's talking about.
See if you can get the actual code NUMBERS.
- brianj
- Posts like an L36
- Year and Trim: 2000 SSEi
2006 GP GXP - Location: Niagara Falls, Ontario
If it is one of the wheel speed sensors on the front don't you have to repalce the entire hub?
Correct.brianj wrote:If it is one of the wheel speed sensors on the front don't you have to repalce the entire hub?
