Question about K and N filter
AJT2004
Post by AJT2004 »
Is it true that the filter has to be oiled, or is that just to clean it. thank you
rm25x
Year and Trim: 2001 Bonneville SLE
Re: Question about K and N filter
Post by rm25x »
Yes it gets oiled with their special oil which is sticky to catch the dirt and dust. They also have a special cleaner for it, then you re-oil it afterwards.
AJT2004
Post by AJT2004 »
how often do i oil the filter, and is that something i should have done before installing it. thank you for the quick response
rm25x
Post by rm25x »
willwren
Post by willwren »
When you eventually need to clean your pre-oiled filter (it says so on the box), make sure you follow the instructions to the letter. To prevent over-oiling (a really bad thing for an expensive MAF sensor), use my method.
Lightly blot the filter about 5 minutes after oiling with a lint-free cloth, on both sides.
AJT2004
Post by AJT2004 »
Okay so it did come pre-oiled, thank you. I plan on cleaning at 25,000 mile. Which one of the oils do you recommend
http://www.knfilters.com/clningacc.htm
willwren
Post by willwren »
The small one (first one listed) should be available at your local parts store (any or all of the stores in your area). That will last you several cleanings if you don't go spray happy.
AJT2004
Post by AJT2004 »
Prefect, thank you
