Sun Visor
Sun Visor
This topic has prob. been discussed a million times, but i could not find it under search. Im trying to removing my headliner and reupholstering it. Im stuck with the sunvisors i cant figure out how to detach them or remove them. Pictures or detail instruction would be amazing.. thanks guys. Im hoping i find the leak causing the water damage coming form the drain pipes under the moon roof.
Re: Sun Visor
There are 3 screws on the pivot side, and the clip side has a plastic pin that you need to pry down with a small screwdriver. Once you can get a grab on the pin, pull it all the way down, releasing the tabs.
Pry here:
Pry here:
