Heating Issue
PLAGUE PHANTOM
Year and Trim: 1968 Chevrolet Bel Air
Heating Issue
Post by PLAGUE PHANTOM »
I just replaced my Blower Motor Resistor and my Blower motor, The heating is great but it only comes out of the floor vents and the defroster. I do not feel any air coming out of the vents on the dash. Please help cause it is severely cold here in INDIANA. If possible would someone please post a tutorial on how to do this.
1997 Bonneville SLE...(SilverStreak)...Totaled...1/25/13...Gone but not forgotten.
1968 Chevrolet Bel Air....the project
LeSabre in Buffalo
Year and Trim: 2012 Eco
Re: Heating Issue
Post by LeSabre in Buffalo »
It's the HVAC vacuum actuator behind the glovebox. Either that, or a vacuum leak somewhere in the lines leading to it. IIRC, if it's broken/no vacuum or off, it defaults to floor vents.
swiles
Year and Trim: 1992 se
Re: Heating Issue
Post by swiles »
make sure you check all the lines one leak could stop the flow of air
willwren
Re: Heating Issue
Post by willwren »
LeSabre in Buffalo wrote:It's the HVAC vacuum actuator behind the glovebox. Either that, or a vacuum leak somewhere in the lines leading to it. IIRC, if it's broken/no vacuum or off, it defaults to floor vents.
An SE doesn't have the airmix actuator behind the glovebox. That's ECC equipped cars only.
Check the vacuum lines near the programmer above the right front hushpanel. Also make sure the line coming through the firewall from the motor has vacuum and is connected.
PLAGUE PHANTOM
Re: Heating Issue
will....my car has Electronic Climate Control.
willwren
Re: Heating Issue
Post by willwren »
Ok, please look at your RPO codes for "H4U". Do you have it? If so, please add "SLE PACKAGE" to either your profile or signature. That's one of the determining factors we use to help troubleshoot cars around here. Nevertheless, it's not the airmix actuator behind your glovebox, as your heat is fine. Does the heat adjust up and down correctly? Is your ECC flashing the temperature on startup, or is it acting normal?
PLAGUE PHANTOM
Re: Heating Issue
Fan speeds work, heating is good, it does flash when i start the car up but it eventually stops.
Last edited by PLAGUE PHANTOM on Sun Jan 23, 2011 11:22 am, edited 1 time in total.
PLAGUE PHANTOM
Re: Heating Issue
problem solved. I replaced the vacuum tank (big blimp object in front of passenger side tire) line because it was completely severed. Heating works great on every vent :banana:
Re: Heating Issue
The evap canister?
PLAGUE PHANTOM
Re: Heating Issue
i don't know what you call it...it is that large pill shaped thing in front of the passenger front tire. The line that comes from it was severed so i replaced the line and it works great now...also did willwrens HVAC cleaning method which may have also helped
willwren
Re: Heating Issue
Post by willwren »
Ed, the Evap canister is on the DRIVER'S side, the vacuum tank for the ECC was relocated to the wheelwell on the passenger side in 1996.
PLAGUE PHANTOM
Re: Heating Issue
so in a way a guess i had a vacuum leak...at least it is fixed now :bwoohoo: :beerchug:
LeSabre in Buffalo
Re: Heating Issue
I was sorta right in a bass-ackwards way, lol.
Glad to hear it's fixed!
