Shock replacement
Sirhc
Shock replacement
Post by Sirhc »
I am having some trouble with these self leveling air shocks. I have already replaced the shocks once but now I think it is something wrong with the compressor. I looked at the price for the compressor and I really dont know if it is worth it. I looked at Rock Auto for the Shock Absorber conversion kit and I would like to know if anyone has done that to their Bonnie?
|| 2002 Bonneville SSEi :: 116k ||
-- Current Mods :: Drop In K&N Air Filter, Rockford Fosgate 6x9's, Code Alarm CA550
-- Upcoming Mods :: 15% Tint, Replace Stock Speakers, Aftermarket HU, Intense FWI
willwren
Re: Shock replacement
Post by willwren »
I'll move this to the proper section for you (Mechanical 2000-2005). This section is for performance upgrades.
Sirhc
Post by Sirhc »
There are things to check before jumping straight for the compressor. When you first start the car, do you hear the compressor come on? Compressor is located right above the right tailpipe / muffler.
Have you checked the fuses?
Sirhc
Post by Sirhc »
myfirstbonnie wrote:There are things to check before jumping straight for the compressor. When you first start the car, do you hear the compressor come on? Compressor is located right above the right tailpipe / muffler.
Yes, the compressor kicks on and it fills up the shocks. After awhile I would feel my car jump up like I have been hit in the rear then the compressor kicks back on. It is really old thats why I am thinking about just going to some regular Monroe shocks. As for the fuses, no.
I would check your level sensor. Sounds like it might have a dead spot. It connects to the driver's side control arm on the rear.
:withstupid: Also check for any leaks in the tubing.
01bonneSC
Year and Trim: 05 Chevy 'Hoe
89 SkiDoo
Post by 01bonneSC »
And Andrew(harofreak00) will more than likely be able to help you out with any parts you need.
From PM:
Sirhc wrote:Subject: Shock replacement
00Beast wrote:I would check your level sensor. Sounds like it might have a dead spot. It connects to the driver's side control arm on the rear.
:helpsmilie: How do I check the level sensor and what I am looking? I'm just a rookie at this car maintenance stuff.. Lol :-$
I would use an OHM meter on the pins where the connector goes in and see if it goes to 0 anywhere, or doesn't go up in spots. You want to see steadily increasing or decreasing resistance (or voltage, I'm not sure how this one runs) from the low to high positions.
Sirhc
Post by Sirhc »
Well, I haven't had the time to fully check it out yet. Now, it is sounding like a semi truck when it goes. The compressor kicks on, fills them up, then I hear a rush of air come out just like a semi truck stopping. This car is just full of troubles for me, but I refuse to give her up.
swampthing
Post by swampthing »
You don't want to bypass with regular shocks nobody has had success with them. Sounds like you have a leak somewhere to me. Also check the top shock mounts behind the carpet in the trunk and see if they are holding, somebody (harofreak00 I believe) has a video of a bad shock mount letting the rod push through
Current fleet:
