Replacing Crankshaft Sensor Yields Interesting Results
Crankshafted
- LE Member
- Year and Trim: '98 SSE
I drive a '98 SSE. One day it just broke down and refused to start. When I try starting it, it seems like it's going to but doesn't actually 'fire', I guess. So I changed out the crankshaft sensor and it started fine, three times actually. So after I clean up and get my tire back on, the same exact problem happens again. Was it a faulty crankshaft sensor or did something else wrong with my car just burn it out? Could it be something else entirely?
- Archon
Re: Replacing Crankshaft Sensor Yields Interesting Results
It could be something else entirely. Are you getting spark? What is your fuel pressure? Try disconnecting the MAF sensor and see if it starts.
- Mechanical Mike
- Retired Gearhead
- Year and Trim: 99 SSEi
The only thing I can think of that would damage the crank sensor is a bent tang on the harmonic balancer. That’s not a very likely scenario unless you recently threw a belt or hit an object in the road. Along with what Archon suggested try reseating the wiring connector at the crank sensor.
Last edited by Mechanical Mike on Sat Nov 20, 2010 11:26 pm, edited 1 time in total.
2006 Chevy Monte Carlo SS
- renchjeep
- Posts like an LG3
- Year and Trim: 1994 Bonneville SE 240k Hot Rod
Check the connections. Dirty, chewed on by animals? Otherwise, an igntion control module, IMHO.
- renchjeep
- Posts like an LG3
Or the often-overlooked fuel filter.
1oldman
Did you get a service engine light before you replaced the crankshaft sensor?
Crankshafted
- LE Member
I got the check engine light and this car has a history of throwing belts and it's done it twice in the past few months.
Is this a good clue?
1oldman
If it has a history of throwing belts I would think the two most likely causes are either a pulley is out of alignment with the rest, or the tensioner pulley doesn't have enough tension in it. It could also be a worn accessory that the pulley wables (water pump, ps pump. alternator, etc), or maybe an incorrect pulley was installed at sometime. It could even be the AC compressor. All but the first two and an incorrect pulley would probably be making some type of noise. I'm sure someone else could think of some other good reasons too.
did you get the code(s) that brought in the service engine light? - BC
Crankshafted
- LE Member
No, I don't have one of those computers and the local shops don't loan them out.
- sandrock
- Retired Gearhead
Most Advanced or Autozones will scan your car for free and "help" determine what caused it. That only will do you good though when your car is running and you can bring it to them.....
- skregal
- Posts like an L27
- Year and Trim: 95 SSEi
05 GXP - Location: Missouri
I didn't catch if you are ACTUALLy getting spark. I would assume you wouldn't have
changed the crankshaft sensor if you were getting spark. If there is no spark and the
crankshaft sensor is new, I agree with renchjeep, look into the ICM.
1oldman
See if they'll "loan" it to you as a rental tool. The O'Reillys here will. If that doesn't work, then stop by every chance you get when they are slow, "shoot the bull" with them, and take'em donuts early in the AM to have with their coffee. Nothin' ever greased a car nut like "neat" cars, fast cars, lots of "good" bs, car talk, and donuts.Crankshafted wrote:No, I don't have one of those computers and the local shops don't loan them out.
By the way, here is a search of OBDII scan tools at Sears: http://www.sears.com/shc/s/search_10153 ... obdii+scan
