Radio Display
robjr69
Year and Trim: 1996 Pontiac Bonneville SE
Radio Display
Post by robjr69 »
The left side of my stereo, I say about a 1/4 of it does not light up. Is this an easy fix? DOes anyone know how or where i can get it fixed
Thanks
Re: Radio Display
robjr69
Re: Radio Display
Post by robjr69 »
How long will it take? this is my only car and I will go crazy without a radio lol
Re: Radio Display
Andrew can have it apart and replace the bulbs in 20 minutes, so it's however long it takes to get to him and get back. 3 days probably.
Re: Radio Display
Ya it all depends on shipping. If you want to expedite it, we can. PM me.
robjr69
Re: Radio Display
Post by robjr69 »
Do u have the 3 bulbs already
Re: Radio Display
Yes
robjr69
Re: Radio Display
Post by robjr69 »
Ok I will let you know by the weekend. I may buy another stereo and then send this one to you to repair then I will have a back up..Thanks for all your help :hail:
Re: Radio Display
If you buy another stereo, you'll need to have it programmed at the dealer. That can end up costing just as much as the replacement. Hence the reason we replace bulbs, because it doesn't require a reprogramming.
robjr69
Re: Radio Display
Post by robjr69 »
Ok, I will let you know..thanks
Ludichris
Year and Trim: 2005 SE
Re: Radio Display
Post by Ludichris »
...is there a link for how to do the Delco radio in a '97 (CD/EQ unit)?? I threw my Alpine head unit in, and I like it a lot, but those Delco units are actually pretty good...I would have left it in probably but the display was out. If the bulb fix is easy, I'll just do it...
My 4th Bonnie...I love these cars!
olblueeyesbonne
Year and Trim: 99 SSEi
01 SLE
02 GTP40th
02 SSEi
06 GP GT
Re: Radio Display
Post by olblueeyesbonne »
Andrew -do you have a radio for him? The Tech 2 is down here in Sauk and my brother has a bench station to plug the radio into for programming VIN's in prior to shipping to the new owners.
DHP Powrtuner & Tech 2
1998 GTP Coupe
1999 SSEi 70k miles
2001 SLE
2002 GTP 40th Anniv Ed Coupe
Re: Radio Display
No, he only has gray button units. robjr is way better off sending his HU to haro.
Re: Radio Display
Ludichris wrote:...is there a link for how to do the Delco radio in a '97 (CD/EQ unit)?? I threw my Alpine head unit in, and I like it a lot, but those Delco units are actually pretty good...I would have left it in probably but the display was out. If the bulb fix is easy, I'll just do it...
Check this out: http://www.pontiacbonnevilleclub.com/fo ... 13&t=14782
robjr69
Re: Radio Display
Post by robjr69 »
I went ahead and ordered the bulbs and me and my best friend took the stereo apart and and replaced the bulbs and it works perfect. thanks for posting the directions on how to do it, your awesome.
