90 SSE Brake and Startup Questions
limabee
Year and Trim: 90 SSE
Post by limabee »
Hey all. Couple of new items that I need some feedback on.
I just did the front brakes on the car and the back breaks are completely new. Since I've gotten the car when I apply the brake hard, the brake and abs light comes on. Most of the time it goes right back out, sometimes it will stay on for a long period of time. No rhyme or reason to it. Mastercylinder is full of fluid. I'm thinking it is the mastercylinder and of course this is the $150-$200 one. Any one know of issues that are fixable or do I just have to swap it out?
When I first put the car together it started almost instantaneously with the turn of the key. Lately, it has been turning over for anywhere from 4-8 seconds before starting. Not sure why and I would welcome any thoughts on that. New fuel pump and filter.
Thanks
Mike
68 Chrysler 300 Convertible
68 Ford Mustang
90 Pontiac Bonneville SSE
98 GMC Yukon SLT
08 Mercury Milan Premier
Re: 90 SSE Brake and Startup Questions
Could the Fuel Pressure Regulator be bad, and leaking fuel down, until the pump can replenish the pressure?
J Wikoff
Year and Trim: 1992 SSE
Post by J Wikoff »
How would that cause an ABS light?
RJolly87
1994 Buick Regal Custom
Post by RJolly87 »
We had this problem with the brakes on our SSE, except it was all the time. The usual cause is a failing accumulator on the ABS system. You can usually confirm it by pumping the brakes up good, and if the ABS and BRAKE lights come on at the same time, and the pedal becomes rock hard <as if ABS took over, but no pulsing> but fades down until you hit the floor. If it does this in 3 pumps or less, you had better start saving up. If you are complaining about $150-$200 master cylinders, you are not gonna like this guy either.
~Randall~
RJolly87
Post by RJolly87 »
J Wikoff wrote:How would that cause an ABS light?
He was offering an explanation of long crank time.
~Randall~
J Wikoff
Post by J Wikoff »
oh...
For the delayed start, disconnect the oil pressure sender and see if it starts at all.
limabee
Post by limabee »
Regarding the brakes, I was thinking it was the mastercylinder. This one comes with a hefty price tag. Any tips when I do get it on bench bleeding the mastercylinder?
The start up is totally random. Today it started once in 2 seconds. I started another time in 8. One thing I noticed is that when it takes a long time it smells like it is loaded up with fuel. Car runs, drives and idles just fine for the record. No issues with lack of power. New air filter, etc.
Thanks guys
Mike
68 Ford Mustang
98 GMC Yukon SLT
limabee
Post by limabee »
Additionally, where is the location of the oil pressure sending switch? Backside of the block underneath?
68 Ford Mustang
98 GMC Yukon SLT
Right by the oil filter.
limabee
Post by limabee »
Popped it off and the car started right up. Not sure of the correllation but it's all good. I think I'm going to pull, inspect and replace the plugs and see what I can see.
68 Ford Mustang
98 GMC Yukon SLT
