Intake manifold gasket
- 89bonnelmj
- SSE Member
- Year and Trim: 1989 LE
I need to change my intake gaskets asap.But Im having a problem with removing the throttle body. How do i remove the coolent tubes that go threw the throttle body?
157,000 miles Mods- polyurethane front endlinks,stb,180 thermostat,ceramic pads,225/60/15 Fuzion HRIs
Re: Intake manifold gasket
They are just held in by o rings. Very carefully wiggle it while pulling. Just curious, why are you needing to change them?
I know the tubes you are talking about as I just did mine. I found it very awkward to remove also. If you bought the felpro intake kit it has those o-rings to replace, you could try spraying a little carb cleaner into their seats which will help loosen those old o-rings up making them more plyable.
68 Chrysler 300 Convertible
68 Ford Mustang
90 Pontiac Bonneville SSE
98 GMC Yukon SLT
08 Mercury Milan Premier
68 Ford Mustang
98 GMC Yukon SLT
- 89bonnelmj
- SSE Member
Thanks guys for the Quick repys
I'm changing them because they have not been changed yet and they are leaking pretty bad. I have to add oil and coolant at times.
