I got tired of jacking up one side at a time
threshold
Year and Trim: 1996 LeSabre Custom
Post by threshold »
This nice piece of seasoned wood was a perfect Imagefit between the control arms. All I had to do was loosen the muffler bolt to get some clearance.
This is on a '95 SE.
skregal
Year and Trim: 95 SSEi
05 GXP
Re: I got tired of jacking up one side at a time
Post by skregal »
I think dragging that jack around on that rock driveway
would of pushed my frustration button.
J Wikoff
Year and Trim: 1992 SSE
Post by J Wikoff »
The FSM calls that out as a floor jack lift point.
2000Silverbullet
Post by 2000Silverbullet »
With two cars in the garage and two out in the driveway..........I have a similar stoned driveway so I feel his pain.
willwren
Post by willwren »
I always jack the whole front up on both cars from the front center. SLEeper's hitch makes a great point to jack the whole rear.
I can literally rotate tires with two jacks on the SLE and rock the car back and forth.
threshold
Post by threshold »
I didn't know that was a jack point. The metal didn't look that sturdy.
The gravel driveway is easy. I used to live on the 3rd floor & had to lug that beast up & down whenever I needed it.
J Wikoff
Post by J Wikoff »
I think the FSM says to use a block of wood like you did.
