HELP!!!
Melissa
Year and Trim: 2000 Bonneville SLE
HELP!!!
Post by Melissa »
After all the other issues with my car, the cd player the heat inside and the exterior temp sensor... it crapped out on me today totally! Lights flicker when I turn it over but no noise like its trying to start. Battery?! I want to cry but all I can do is kinda laugh bc too much has gone wrong with this car since I've had it for the past 4 months. Getting mad won't fix it.
2000 SLE
J Wikoff
Year and Trim: 1992 SSE
Re: HELP!!!
Post by J Wikoff »
Corroded battery post connection?
Re: HELP!!!
That is what mine did. Do you have the original AC Delco battery? I just replaced the one in my 2k last summer.
Melissa
Re: HELP!!!
Post by Melissa »
there's absolutely no corrosion on the battery it has to b just the battery itself. im hoping thats it bc it won't b expensive & its an ez fix. I think it is an AC delco one tho i remember seeing the side of it when i checked the connection
2000 SLE
Re: HELP!!!
It is the vented type. Mine was $175 from Napa. Make sure you get a vented one.
Melissa
Re: HELP!!!
Post by Melissa »
WHOA! Totally can't be spending over $100 on a battery. That's a definite no can do! lol Spent too much on it as it is and I'll be having to borrow from my dad to get one on top of that.
2000 SLE
bonnevillain
Re: HELP!!!
Post by bonnevillain »
Fleet Farm sells a roadrunner brand for about $75.. No stores in Michigan though, as far as I know.
Re: HELP!!!
Interstate lists $170 or so for a stock replacement. They are not cheap, and there isn't much you can do about it.
Archon
Re: HELP!!!
Post by Archon »
Advance Auto Parts shows one for $130, not including the core charge. Autozone for $133
1fatcat
Year and Trim: before cars
Re: HELP!!!
Post by 1fatcat »
That battery is expensive. I priced the crap out of one for a friend and the cheapest I could find was 170. Someone else here had issues just a few days ago with exterior temp and other things acting up. You may want to search and watch that post?
sonoma_zr2
Year and Trim: 1999 SSEi
1997 SSEi-Resting-353K
Re: HELP!!!
Post by sonoma_zr2 »
my son-in-law just put a regular battery in his Rora, always wondered why people don't do that?
ChilinMichael
Year and Trim: 2004 Volvo S60
Re: HELP!!!
Post by ChilinMichael »
Because of this when googled:
All batteries contain sulfuric acid and can generate explosive gases
If your son-in-laws Aurora has the battery under the back seat and he used a regular battery that's not ventilated, it could potentially blow up.
bonnevillain
Re: HELP!!!
yeah, we have vent tubes on our batteries that vent to the outside.
1fatcat
Re: HELP!!!
Post by 1fatcat »
Yep. Also, if the battery is venting acid and you don't have the vent tube hooked up properly or don't have the proper battery, the acid will leak onto the floor of the car and it WILL eat a hole through your floor. I have repaired a couple of floors in Buicks because of this scenario. One had a small hole the size of a quarter, the other had a hole the size of a softball.
Re: HELP!!!
The 02 SSEi I parted out had a leaking battery and there was battery acid residue everywhere under the seat. There was a hole rusted about the side of a softball under the battery. The owner had put a piece of cardboard under the battery to cover the hole. :angry7:
We just put a battery in Shannon's 2000 SSEi. Got it from O'Reilly's for $96. It is a little smaller than the OEM battery, but it has a higher CCA. I had to modify the vent tube a little, but it does have the vents.
Melissa
Re: HELP!!!
Post by Melissa »
Went with my dad today and got one for $70. Took care of the Cd player issue too!! Starts up a million times better than it has since I got it. The battery that came out was Sparton brand. Never heard if it. So she's up and running again but the exterior temp is still off by over 100 degrees!!
2000 SLE
