update on my engine issues...
Mechanical Mike
Year and Trim: 99 SSEi
Re: update on my engine issues...
Post by Mechanical Mike »
It's probably the correct rod but is bent.
2006 Chevy Monte Carlo SS
chris c
Year and Trim: 1995 ssei
Post by chris c »
Mechanical Mike wrote:It's probably the correct rod but is bent.
did not look bent and is coming up WAY short...
it is the only new rod in engine, must be too short.
Mechanical Mike
Wow, where did the long block come from?
Last edited by Mechanical Mike on Tue Dec 29, 2009 12:14 am, edited 1 time in total.
1fatcat
Year and Trim: before cars
Post by 1fatcat »
1fatcat wrote:If no large air leaks are found
(less than 20% leakage), suspect a bent connecting rod.
How do I reach these kids?
J Wikoff
Year and Trim: 1992 SSE
Post by J Wikoff »
Is it a SII rod?
chris c
Post by chris c »
it is a NEW rod. zero mileage engine, it is not bent.
J Wikoff wrote:Is it a SII rod?
tdc and bdc are ~1" less on cyl 1. i suspect the rod is a SII in the SI engine.
Post by Jrs3800 »
Wow... If thats the case, someone made a serious mistake...
and as asked where did you get the longblock?
1fatcat
Post by 1fatcat »
chris c wrote:it is a NEW rod. zero mileage engine, it is not bent.
What I ment was, I would have thought you would have checked piston to deck height when it was apart, after I had suggested a possible bent rod. Even though it isn't bent, you would have found it last time it was apart if you had checked.
chris c
Post by chris c »
i am not going to disagree with you, you live and you learn...
i would have NEVER expected the rod to be incorrect, i had the rod/piston out and it was fine.
oh well, i should be up and running soon.
chris c
Post by chris c »
