Just a friendly reminder that with cold weather comes lower tires, due to the air contracting in the tires. Every 10 degree drop equals about 1 psi. Tires in our Suburban were about 5 psi low each, and I haven't checked miy car's yet (will in a few). Just because your car has TPMS (00+ SLE, SSEi, GXP) just means it compares all 4 tires. If they all drop the same, it won't go off. Not having tires at proper pressure can hurt mileage and cause irregular wear. Check your door tag for the proper pressure.
EDIT: Just checked the tires in my car, they were all at 28 psi, and I had them at 34 psi a month ago, when it was 40-50 degrees outside. Goes to show how much they can lose.
Check Your Tires!!
Check Your Tires!!
Ol' Timer
- Year and Trim: 1991 Olds 88
- Location: New Jersey - Most of Our Elected Officials Have Not Been Indicted
Re: Check Your Tires!!
Yep! Mine lost 4 psi since I last checked them and the air temps were warmer. But when I arrive in Florida I'm sure I'll gain a few pounds.00Beast wrote: Just checked the tires in my car, they were all at 28 psi, and I had them at 34 psi a month ago, when it was 40-50 degrees outside. Goes to show how much they can lose.
2006 Salsa Vibe - Auto - Side Curtain Air Bags - ABS - Vehicle Stability Control - Tunes No Moon - Monotone - Preferred Package - Slate Cyper Cloth - Steelie Wheels
2002 Snap Orange Beetle - Auto - Turbo
1991 Dark Garnet Red Oldsmobile 88 - Donated to Science
bonnevillain
- Year and Trim: 2002 SLE
Yeah I actually got the warning this morning on my way to work. They didn't look too low when I got out though. I'll fill them tomorrow morning.
ChilinMichael
- Posts like a Northstar
- Year and Trim: 2004 Volvo S60
Thank you Ed, something not everyone knows and should be aware of...it can cost you a few MPG if you don't keep proper pressure and with prices these days, air is free gas is not....inflate people!
- BonneMe
As ryan was getting to, Going by how a tire looks is a bad idea.
My winter tires were under 20psi upfront once the first cold snap hit.
- WhiteArrow3800
- Moderator / Social Dev
- Year and Trim: ___
2009 Pontiac G8 GT - Location: Williamsburg, Va
Thanks Ed, I checked my tires...I've got probably less than 1% tread left and two industrial sized staples and a nail.
Also have flat spots on both rears...that's a separate issue...they'll be replaced soon.
But seriously they were also all under by about 5psi each.
Last edited by WhiteArrow3800 on Wed Dec 16, 2009 11:23 pm, edited 2 times in total.
l67poweredlss
- Year and Trim: 1997 Oldsmobile LSS L67
2009 SBM G8 GT
Started the G8 a few days ago and its freakin' about 30-32psi on all fours.
