Average miles per tank, SSEi owners
alec_b
Year and Trim: 1996 SSEi, Bright White, Medium Teal, 197k
Post by alec_b »
Last tank I got about 330 miles. That was using about 15 gallons, with maybe a 75/25 highway/city split. That works out to about 22 MPG. Not great.
Any ideas where to look? It runs great, no codes, new plugs wires ICM and fuel filter. It's always gotten about the same since I got it. Or am I just hoping for too much?
Mods: Clear corners, gutted airbox, Alpine CDA-9886. Plans: 4x SensaTracs, high-flow, FM 80, 3.5 pulley, and for gods sake some good rubber.
Re: Average miles per tank, SSEi owners
Remember that you probably are on Winter Blend, which will give worse mileage than summer blend.
olblueeyesbonne
Year and Trim: 99 SSEi
01 SLE
02 GTP40th
02 SSEi
06 GP GT
Post by olblueeyesbonne »
I too have the same issue. Although, those #'s match my summer #'s. My winter #'s have me putting 18 gallons in every 250 miles.
I'm very much considering getting an older LN3 Olds Touring Sedan for winter use. Still have most of the features and amenities, but in an older car that I won't worry too much about and will get over 25 mpg year round.
DHP Powrtuner & Tech 2
1998 GTP Coupe
1999 SSEi 70k miles
2001 SLE
2002 GTP 40th Anniv Ed Coupe
repinS
Moderator
Moderator
Year and Trim: 09 G8 GT
Post by repinS »
Yeah, like Marty said, that's about right for me in warmer weather. Straight highway, in the summer 30+ is easy, 23 with a 50/50 mix.
100% city, I've been seeing about 16mpg lately.
alec_b
Post by alec_b »
Ok good deal, so it's not just mine.
I guess I'm almost on the high end of average, not bad for having 205k on it. I think I'm going to need to get something smaller though, it's getting too expensive for the amount of driving I do. I manage to put on several thousand miles a month, I need something that's a litte more sippy and a little less gulpy, if you know what I mean.
1fatcat
Year and Trim: before cars
Post by 1fatcat »
You could get an old geo metro :)
I would rather get poor gas mileage and some get-up-and-go before I would buy a metro. [-X
PRD2BDF
Post by PRD2BDF »
You're using premium right? I just wanted to check...
zuper8
Year and Trim: 96 SSEi- 157K
Post by zuper8 »
I always run 93 octane, and I see maybe 16-18 city, and 23-27 highway depending on how I drive. it's got all the tune-up goodies too. i've heard people say that you can get just as good of mileage with the SSEi as you can an SE, but I haven't been able to do it yet. my SE got 33+ highway without me even trying. i've just accepted it. and really, that's not to bad for being a huge car with a supercharged motor.
- Rachael
It's better than my dad's GXP. No matter how well he drives, 21 is the limit on that car, unless you're cruising down the interstate at 65.
'96Bonnevillel67
Year and Trim: 1996 Bonneville SSEi
Post by '96Bonnevillel67 »
zuper8 wrote:I always run 93 octane, and I see maybe 16-18 city, and 23-27 highway depending on how I drive. it's got all the tune-up goodies too. i've heard people say that you can get just as good of mileage with the SSEi as you can an SE, but I haven't been able to do it yet. my SE got 33+ highway without me even trying. i've just accepted it. and really, that's not to bad for being a huge car with a supercharged motor.
Ever considered non-oxygenated? Find someone with a good scan tool with a live data function, monitor your LTFT/STFT, spark, o2's etc. Do both WOT and cruise. (o2's don't matter a cruise, they jump all over.)
I haven't seen a change in consumption at all with it dropping down to ~25* unless I run regular oxygenated gas.
If you get into it even once you'll suck gas down to compensate for the cold, especially with mods/tune.
Cold shouldn't matter if you adjust your driving for it. Larz01 just recorded just over 30mpg at ~65mph in an '01 GTP. And I'm still averaging 22mpg city with quite a few "pulls."
Driving nice will still net me upper 20's.
Last edited by '96Bonnevillel67 on Wed Nov 18, 2009 3:50 pm, edited 2 times in total.
alec_b
Post by alec_b »
I was running the BP non-oxy for a little while, didn't make a difference. I've used everything from 91-93 octane, doesn't make a difference. I think i'll grab the scanner from work and pull some data and see how it looks.
Larz01
Year and Trim: 2K1 GTP
Post by Larz01 »
I just turned up cruise timing and put my torque converter back to stock & stock stat. Got 31 mpg driving up north this weekend, made the 400 mile trip on 1 tank of gas. In town i get 26 can be a combination of mods and tuning to get this as my vehicle doesn't have to work as hard to pull its own weight.
"you probably are on Winter Blend" - no delineation here
"Ever considered non-oxygenated?"
Just Your Average open loop tuned Ethanol Driven DD's
2k1 GTP: 13.307 @ 104: Headers, 1.9's, Tune
2k12 Impala: Stock
'96Bonnevillel67
Forgot to mention, still running a 180* stat in this cold.
repinS
Moderator
Moderator
Post by repinS »
'96Bonnevillel67 wrote:Cold shouldn't matter if you adjust your driving for it. Larz01 just recorded just over 30mpg at ~65mph in an '01 GTP. And I'm still averaging 22mpg city with quite a few "pulls."
On long-haul trips, yes.
Those who do shorter trips (average city-highway mixes) will have to deal with the extended period of time in open loop before everything gets up to temp.
'96Bonnevillel67
Yea, and most of my trips consist 15min of highway, 15min of stop and go with aggressive driving on occasion, and with mods, and a much richer than stock tune, but I can still muster no less than 22mpg combined in ~35* weather with a 180* stat. In fact, more often than not, it's mostly city for me.
Tri-State with the runs at the track I averaged ~25.5mpg, and that was with 32* temps and no change in my cruise spark with a fully loaded car.
There's something wrong with his fuel consumption, that's all I'm pointing out.
Last edited by '96Bonnevillel67 on Thu Nov 19, 2009 2:11 pm, edited 1 time in total.
dangrus4060
Year and Trim: NEW 99SSEi
Daughter-97SEw/SLE Opt
98SSEi Wrecked
Post by dangrus4060 »
i usually run aobut 330-350 miles on about 17 gallons so thats about 20 mpg average. i run 93 octane BP Ultimate.
i usually run about 50/50 city/highway combo (70-75 mph avg. on I-40 here) and i do drive a little aggressive. LOVE THAT WHINE!!! (with front of air box gone i hear it nicely with just moderate throttle)
i've only done 1 good road trip since i got it and i got about 27 hwy thru the mountains.
Dangrus4060
99 SSEi Galaxy Silver w/Dark Pewter Leather, Bought Aug. '08 w/75,000 mi. Bose Sunroof Michelins 35% Charcoal Tint(max. legal) Gutted Airbox w/K&N Drop-in 180Deg. Drilled Stat. Flushed Dex-Col Castrol Edge 10W30 w/PureOne Dual Chromed-Stainless Exhaust Tips Avital - Avistart 5303 Remote Start w/Security SilverStar Ultra's HL Rebuilt Motor w/New Crank & L32 Powdered Metal Connecting Rods
Daughter's 97 SE w/SLE White w/Dark Pewter Leather Bought Apr '06 w/153,000 mi. AM/FM/CD w/ 7-Band EQ Gutted Airbox w/K&N Drop-in
180Deg. Drilled Stat. Flushed Dex-Col Valvoline Max Life 10W40 w/Pure One Avital - Avistart 4300 Remote Start w/Security
TDS-94SSEi
Year and Trim: 1994 SSEi
White w/ grey int
Stock
Post by TDS-94SSEi »
I think our '94 gets something around high-teens around town. But it it hard to stay off the go-pedal, so i accelerate it somewhat aggressively a fair amount. i've never actually tried to calculate how the car does on the freeway trips, probably should some time. . . .
TomS.
1994 Pontiac Bonneville SSEi
sold Dec, 2014
alec_b
Post by alec_b »
Well thanks for all the replies guys, but the car is gone as of this past thursday! Time to move on to another project.
Thanks for all the replies!
1fatcat
Post by 1fatcat »
So what did you end up trading for? I have a neighbor with an 88 honda civic and I asked him, but he said he was not interested in trading. I couldn't/still can't believe he didn't want to trade.
