I got ahead of myself
bonnevilleSSEiman
Year and Trim: 2002 Bonneville SSEi
Post by bonnevilleSSEiman »
I recently put a 3.4 inch pulley on my 2002 ssei and have 5* of knock..i'm gonna go back up but should i go to stock size or maybe a 3.5 or 3.6
my mods are
Intense FWI, Intense PCM, NGK TR6 gapped at .60 and a 180* tstat. The knock was not that high before i moved to Minnesota, i didn't account for the climate change..lol
Thanks in advance
James
Last edited by bonnevilleSSEiman on Tue Nov 03, 2009 2:07 pm, edited 1 time in total.
2002 Galaxy Silver SSEi Mods- Intense PCM, Intense FWI, Belden Wires, NGK TR6 , 3.4 MPS(2 much knock lol), JVC arsenal HU, PACSWIX, Solid Front Mount, 18inch MB Drifters w/ 245/45/R18 BF Goodrich GForce TA KDWs,Chrome Dual-outlet tips
00Beast wrote:If the aeroforce were any more idiot-proof, Fisher Price would sell it for 3 year olds.
01bonneSC
Year and Trim: 05 Chevy 'Hoe
89 SkiDoo
Re: I got ahead of myself
Post by 01bonneSC »
Where did you move from?
bonnevilleSSEiman
mississippi don't know if it's the altitude or what
James
I'd go with a 3.6, and see what that gets you. I still have 3-4* KR on a 3.6, with an intake, 180* T-stat and AL 605's. My next mods (downpipe and PLog) should eliminate that KR.
EDIT: That's on my stock PCM, BTW.
bonnevilleSSEiman
alright i'd like to have as little as 2* or none. Think i can do that with a 3.6 since your getting 3-4 on it wth a stock PCM? I'd say yes but i don't want more then 2*. Thanks.
James
It all depends. Every car is different. You'll have less KR, that's a fact.
bonnevilleSSEiman
00Beast wrote:It all depends. Every car is different. You'll have less KR, that's a fact.
true..all cars are different...i might just take the car back to stock completly and deal with it in the spring.
olblueeyesbonne
Year and Trim: 99 SSEi
01 SLE
02 GTP40th
02 SSEi
06 GP GT
Post by olblueeyesbonne »
I'm running a 3.6" MPS from http://www.smoothflowpulleys.com (local here in MN and Nate is a VERY good person to deal with).
Anyhow, with my 3.6" I'm getting up to 15* KR at times now. Used to be I was getting 9* occassionally, but because it wasn't consistant (sometimes in dead heat I could run a 3.4" with 1-2* KR and then sometimes it'd be 9*, so I switched back to the 3.6" and still no change except for now I think I've found my culprit- rear trans mount).
My mods are ZZP 1.0 pcm, drilled 180* t-stat, autolite 104's (.054"), Belden Max 8mm wires, Intense 3.5" FWI, MM ceramic coated front PEM, Alex Exhaust 3" mandrel bent DP (catless), 3" truck resonator and 3" mandrel bent mid-pipe, Borla ProXS crossflow muffler, ZZP S1 HVTB (72mm vs stock 69mm), ZZP TB spacer, ZZP UDWP pulley, and one or two other mods I can't recall atm.
If we can figure something out with Black Pearl's 02 SSEi for tuning you should make the drive up to Albany, MN for some tuning to eliminate KR and you may be able to run the 3.4" with minimal or no knock -these cars can vary drastically -Black Pearl's 02 SSEi has only a FWI, 3.4" and 180* IIRC and he only has 3-4* knock with stock PCM and exhaust which is VERY RARE.
DHP Powrtuner & Tech 2
1998 GTP Coupe
1999 SSEi 70k miles
2001 SLE
2002 GTP 40th Anniv Ed Coupe
You are going to have less KR in winter than summer. If you have 5° in winter, you will have 10° in summer. Deal with it now.
Larz01
Year and Trim: 2K1 GTP
Post by Larz01 »
Put a stock size pulley on because the air is more dense, plus we don't have great premium gas in MN.
Just Your Average open loop tuned Ethanol Driven DD's
2k1 GTP: 13.307 @ 104: Headers, 1.9's, Tune
2k12 Impala: Stock
Black Pearl
Post by Black Pearl »
olblueeyesbonne wrote:If we can figure something out with Black Pearl's 02 SSEi for tuning you should make the drive up to Albany, MN for some tuning to eliminate KR and you may be able to run the 3.4" with minimal or no knock -these cars can vary drastically -Black Pearl's 02 SSEi has only a FWI, 3.4" and 180* IIRC and he only has 3-4* knock with stock PCM and exhaust which is VERY RARE.
You're right Marty. I looked back to the scan you PM'd me and it was 3-4* at wot in second. Any luck on a file for tuning?
Bonneville Forum COTM Sept. 09
Pontiac Bonneville Club COTM Dec. 09
bonnevilleSSEiman
harofreak00 wrote:You are going to have less KR in winter than summer. If you have 5° in winter, you will have 10° in summer. Deal with it now.
funny you say that because i scanned the car in June using a Tech 2 and only saw 1* when the car shifted...nothing at WOT...think it might be something else? should go back to a 3.6 or go back to stock and start checking the car over?
James
Larz01
Post by Larz01 »
bonnevilleSSEiman wrote: think it might be something else?
-Got a scan?
Your car is seeing more boost than summer on the same pulley, I'm hitting over 10 psi on a 3.6 pulley compared to 8 in summer. Put bigger pulley on or [pull timing :evil: ]... P.s. You need more supporting mods for a 3.4 to run kr free w/ decent timing.
2k12 Impala: Stock
SSEimatt93
Senior Moderator
Senior Moderator
Year and Trim: 2016 Scat pack
Post by SSEimatt93 »
Im running a 3.0 MPS,in the heat I can pull around 4 degrees, normally, its not much.
2016 Dodge Charger Scat Pack 392
3.09's 8 Speed Auto
04 GTP
bonnevilleSSEiman
ok..i'm gonna go with a 3.6 and see what happens...can i use the stock size belt with it? I don't see the 3.6 listed on the intense website as needing a smaller belt.
James
bonnevilleSSEiman
and btw thanks for all the help. I'm still new to this whole modding thing and i jumped the gun and went straight to the 3.4. Lesson learned. Once finances are straightened out and all i'll come back to modding this car.
James
SuperSLE
Year and Trim: sold
Post by SuperSLE »
I'm running a 2.8 on pump gas and a Gen V with 0KR. Now take that with a grain of salt because I have mods up the wazzu. But, There is something wrong if you are getting any KR. Tuning will help a lot. I'd narrow the spark plug gap if you are still at .06 and drop a heat range. I'd also check your fuel flow, basic tune up, etc. Bonnies seem to have a lot more issues with KR for some reason and I don't know why. I think it has a lot to do with the PCM and tuning being a lot more conservative.
2000 SLE
SAMzGXP
Post by SAMzGXP »
looking at your mod list, 1st i believe you're running wrong plugs.. you should have colder plugs the AL 104 are colder than the NGR which will reduce the knock a little bit (had same problem with my GP) also i can see you're running a smaller pulley and an intake but no exhaust work, all that extra air going in it needs to go out, so i would really recommend a 3" DP and maybe a Plog (also not sure if bonnevilles have the stupid Ubend like GPs did).
i was running 6 KR* before in my GP and installing AL 104 gapped at .055 helped alot, btw what kinda boost are you having? just wondering what it would be like with stock DP, hope you're not boost stacking
btw im comparing this to my GP which im assuming they are very close to be the same.. if im wrong someone please correct me.
Cardomain link
Fully tinted, 5000K HID hi/lo & fogs, LED conversion (interior/red rear signals/reverse light/license plate/trunk/sun visor/glove box/switch backs), turn signal mirrors, JVC KW-NT3 Navi & BT, KV-CM1 Camera, 2x JL 13TW5, JL G-Max, black & chrome emblem, 20" black & red, clear corners, center tail light up, half tinted tail lights, cross drilled rotors, Hawk ceramic pads, and more..
Black GXP. One of a kind. RIP.
G35 Coupe 6MT. Stockishhh
bonnevilleSSEiman
i'm running a 3.6 now..all is well :banana: and TR6 is one heat range colder than stock...i am running stock gap though. I'll be doing exhaust in the spring.
Thans for all the input :)
James
No problem. That's why we're all here!!
