Even though its been raining all day yesterday and today, I decided to go work on the car a little bit.
I tried charging the original battery last night, but it was bad. Guess who happens to have a spare laying around. I put the spare battery in and fired it up. It started amazingly for not being run for ~3 months. The engine runs smooth and quiet. MUCH quieter than my modded car. I kinda miss that sound. I backed it off the trailer and pulled it in the driveway. Transmission works great in drive and reverse.
Here are some more pics
As you can see, there is no structure damage.
Interior needs a good haro cleaning
All the cluster lights work, YAY! 102k
A bit dirty
Here is how the truck looked
Here is the trunk cleaned out
And here is everything that was in the trunk. I was pleasantly surprised to find some of those parts. Headlight, floormats, foglights w/ brackets (tinted), license plate, center cap, hood latch, fender well liners, and that plastic bag contains all the bolts that were removed when car was dismantled.
Found all this water in the trunk
Drilled a 1/8” hole in the bottom to let the water drain out.
