Castrol Edge
- BlackHawk99
- Senior Moderator
- Year and Trim: _
Castrol Edge
Has anyone here tried it? It's advertised as being 8x better than Mobil 1.
2012 Ford Fusion SEL, 2012 Chrysler Town & Country, 2007 Chevy Silverado LT, 1999 Pontiac Firehawk, 1979 Pontiac Trans Am
lewis26
- Posts like an L27
- Year and Trim: 2003 SLE || 51k miles
Re: Castrol Edge
Think with your dipstick Jimmy!
-Mike
LeSabre in Buffalo
- Year and Trim: 2012 Eco
Re: Castrol Edge
I've heard it's supposed to be Castrol's version of Mobil 1 EP.
There's a $15 rebate on it currently. http://www.castrol.com/castrol/sectiong ... Id=7055585 Can also be combined with the $10 Advance coupon. And guess who is having a sale on Edge for $25? Advance. Yep, potentially free (plus taxes/postage) Edge!
Barry
- Posts like an L27
- Year and Trim: 1999 SSE
Re: Castrol Edge
I was just on the Advance Auto website and found nothing about it being on sale or a coupon. Where did you get the coupon?
1999 SSE. 112k, Cleared Corners, Mobile 1, Energy Suspension endlinks. Ported and Polished LIM, NGK TR-55 Sparkplugs, 180 drilled Intense stat, Flow matched injectors, Intense FWI, Intense PCM, MagnaFlow Cat.
dangrus4060
- GXP Member
- Year and Trim: NEW 99SSEi
Daughter-97SEw/SLE Opt
98SSEi Wrecked - Location: Winston-Salem, NC
Re: Castrol Edge
I got mine in the mail yesterday...
I seriously thinking of changing to this... after what happened to my engine with Mobil 1.
Dangrus4060
99 SSEi Galaxy Silver w/Dark Pewter Leather, Bought Aug. '08 w/75,000 mi. Bose Sunroof Michelins 35% Charcoal Tint(max. legal) Gutted Airbox w/K&N Drop-in 180Deg. Drilled Stat. Flushed Dex-Col Castrol Edge 10W30 w/PureOne Dual Chromed-Stainless Exhaust Tips Avital - Avistart 5303 Remote Start w/Security SilverStar Ultra's HL Rebuilt Motor w/New Crank & L32 Powdered Metal Connecting Rods
Daughter's 97 SE w/SLE White w/Dark Pewter Leather Bought Apr '06 w/153,000 mi. AM/FM/CD w/ 7-Band EQ Gutted Airbox w/K&N Drop-in
180Deg. Drilled Stat. Flushed Dex-Col Valvoline Max Life 10W40 w/Pure One Avital - Avistart 4300 Remote Start w/Security
ChilinMichael
- Posts like a Northstar
- Year and Trim: 2004 Volvo S60
Re: Castrol Edge
Just about anything is 8x better than Mobil 1 these days....BlackHawk99 wrote:Has anyone here tried it? It's advertised as being 8x better than Mobil 1.
LeSabre in Buffalo
Re: Castrol Edge
Post with $10 coupon. Need to fill out a survey. Print out as many as you think you may need.
http://www.pontiacbonnevilleclub.com/fo ... =7&t=14494
Check their ad or go to the store. 5 qts. Edge with a PureOne for $25.
- Archon
Re: Castrol Edge
I found out about it when I went in to Advance to get the Purolater filters. Unfortunately, I had already bought some Valvoline SynPower so I didn't need the oil.
Barry
- Posts like an L27
Re: Castrol Edge
Oil keeps well. You should have bought some and saved it for next time.Archon wrote:I found out about it when I went in to Advance to get the Purolater filters. Unfortunately, I had already bought some Valvoline SynPower so I didn't need the oil.
- Archon
Re: Castrol Edge
Didn't work in to the budget.
dangrus4060
- GXP Member
Re: Castrol Edge
I went ahead and got 5 qts of The Edge and a PureOne filter to change my oil Saturday morning before going to Virginia for the weekend for my niece's wedding.
Satisfied so far. Still gotta send in for the rebate. Printed it but just haven't gotten it done.
I know this is a long life oil but I think I will change at 5000 miles to check everything out.
BTW, when I chenged the oil this weekend, I checked the tip of the magnetic drain plug for and metal debris or residue and found none. Engine is super clean after rebuild.
Still dont understand why the #1 rod bearing spun and failed...
Dangrus4060
Barry
- Posts like an L27
Re: Castrol Edge
Glad to hear the rebuild seems to have gone well. As for what happened, sometimes things happen that have no rational explanation. They just do.
rrounds
- Posts like an L36
- Year and Trim: 2000 SSEi
Re: Castrol Edge
No Advanced Auto in Calif.
Any other auto part stores have that $10 off coupon ?
Or is Advanced Auto part of some other parts store under another name ?
ROD
ROD
2000 SSEI (SOLD)
rods789 at comcast.net
PB 14.474 @ 96.248 PB 60' 2.168
180 therm AEM DRYFLOW Air Filters
3.33 pulley 3" cat back exhaust
custom solid front motor mount
custom 6" (BIG) intake
__WCBF '06, '07, '08, '11 survivor__
- BlackHawk99
- Senior Moderator
- Year and Trim: _
Re: Castrol Edge
Advance and Parts America used to be one in the same. Not sure if that's still the case. Got any Parts America stores in CA?
ChilinMichael
Re: Castrol Edge
It's not the case anymore, Advance barely has anything at all anymore
rrounds
- Posts like an L36
Re: Castrol Edge
I took a look at the Castrol Edge oil at WallyWorld and they want $7.49 a qt., so that is still over $37 for 5 qt's. with the $15 off rebate. If I can find it on sale somewhere it might be worth it to get 10 or 15 qt's. I just have to use 2 or 3 addresses(one rebate per address). But $37+ for oil is to much for me to spend, I like it when I get M-1 on sale at Costco(get it for $3.00 per qt.)
ROD
ROD
2000 SSEI (SOLD)
wjcollier07
- Year and Trim: ____
Re: Castrol Edge
What exactly do you mean by that? They just redesigned their entire website? Seem to be doing just fine?ChilinMichael wrote:It's not the case anymore, Advance barely has anything at all anymore
And I'm still waiting for something to compare with Amsoil. And if I want "full synthetic" instead of actual PAO based 100% synthetic, Mobil1 is still on my list, right along with the known quality of Valvoline SynPower and Pennzoil Platinum.
John
ChilinMichael
Re: Castrol Edge
What I mean by that, and I don't like to get off topic, so sorry to author, I'll make this fast. When Advance was linked with PartsAmerica it was due to another company, I believe called Checker Auto Parts, also. Whenever I looked up say "Water pump" for my car, I had like 7 choices, now there's literally one choice in every part, they've gone from the parts store with the most choices around here to the least choices, at least for my car.
- grandprix104
- Year and Trim: 2001 SE L36
Re: Castrol Edge
CSK (Checker/Shucks/Kragen) Auto parts used to share thier online catalog with Advance. CSK was just bought by Oriely's and that's why Advance is no longer is working with them. BTW CSK stores are very common out west and Advance is barely heard of. On a side note CSK stores prices went through the roof, thier price beat garrantee went away, and thier service sucks worse than Autozone since the big O bought them.ChilinMichael wrote:What I mean by that, and I don't like to get off topic, so sorry to author, I'll make this fast. When Advance was linked with PartsAmerica it was due to another company, I believe called Checker Auto Parts, also. Whenever I looked up say "Water pump" for my car, I had like 7 choices, now there's literally one choice in every part, they've gone from the parts store with the most choices around here to the least choices, at least for my car.
As far as oil goes, with all the complaints of Mobile 1 nowadays I just switched back to Valvoline. It's cheaper and works great for me!
Re: Castrol Edge
I have also switched to Valvoline and valvoline synthetic as opposed to M1
