2000 sle sunroof...
excessive81
- Year and Trim: 2004 white diamond gxp
2000 sle ss
2000 sle sunroof...
sun roof wont vent...anybody know the fix. act when you close it it dont pop all the way flush with the roof in the rear
CaliSSEi
- LE Member
- Year and Trim: 2001 SSEi Sold. Thinking about a 2005 GXP
Re: 2000 sle sunroof...
There are four torx type screws, one at each corner of the sunroof accessable from the inside. Try loosening (don't remove) these, then adjust the glass to where you want it and then re-tighten the screws. I hope it's not a problem with your track/actuator assembly. That would be a bigger problem to fix. Good luck ! George.
P.S. We need to get Harofreak00 to work on these, as well as those irritating radio lamps,
well keep that guy busy !
I would remove the glass completely and make sure the arms are working correctly first.
