Digital Displays
slerby1st
Year and Trim: 1998 Bonneville SSEi 4door 3.8 Supercharger
Digital Displays
Post by slerby1st »
All the displays in my car go blank when in extreme sunlight. Is this normal or is there a problem with the twilight sentinal switch? They seem fad in and out more when I have the sunroof open. can someone please advise. Thanks
ChilinMichael
Year and Trim: 2004 Volvo S60
Re: Digital Displays
Post by ChilinMichael »
Do you notice if the internal lights are on ? (Meaning dash lights)
J Wikoff
Year and Trim: 1992 SSE
Post by J Wikoff »
Do they actually change in brightness or is it that you cannot see the contrast when bright light hits the display? I suspect the later. It's just how LCD displays are.
slerby1st
Post by slerby1st »
They dim out when bright light hits them and sometimes they dim out for no apparent reason and when this happens I hear a clicking noise.
repinS
Moderator
Moderator
Year and Trim: 09 G8 GT
Post by repinS »
Sounds like the automatic headlights coming on and off.
By extreme sunlight, do you mean high noon, or in-your face sunlight at dawn and dusk? If it's the latter, the lighting conditions outside are getting just dark enough to trip the lights on and off. I just force 'em on manually in this case.
J Wikoff
Post by J Wikoff »
slerby1st wrote:They dim out when bright light hits them
That really just sounds like a typical LCD display. The digits get washed out by direct light.
Is the clicking rapid and random, or just one click?
Cheetah
Year and Trim: 97 White Ei 197K
97 Black SE/SC 185K
Post by Cheetah »
You could try unplugging the photo sensor.
LeSabre in Buffalo
Year and Trim: 2012 Eco
Post by LeSabre in Buffalo »
Get a ScanGauge II. Then the gauges you need will always be visible no matter what the light.
I'd not unplug the photo sensor if you want to retain the auto-light feature.
slerby1st
Post by slerby1st »
I hear one click and the displays dim out and I would hear it again and the displays brighten. It only happens during the day light hours, more so when it is very bright out.
J Wikoff
Post by J Wikoff »
Sure sounds like the automatic headlights coming on at the wrong times.
slerby1st
Post by slerby1st »
Is there a sensor or relay for the auto headlights and so where is it found on the car.
ChilinMichael
Sensor is on the dash, right infront of you, little round black disc inside a hole, easy to see. Try cleaning off the top of it with a rag and windex or something of that nature.
