Intense pcm reflashing's
J. Baker
Year and Trim: 2002 pontiac bonneville SLE
Post by J. Baker »
I recently had miy Pcm re-done (standard pak) and then i had my crank sen. re-learned and everything work's great motor wise but after my tranny get to temp it starts to slightly slam shift... now it didn't do this before (the pcm got done) and since i've changed the filter and still no change ( any sugg?)..... I no it's not my tranny it's in the com. or a sen. ... i just want to no if there's anything else that need's to be re-learned or should i just deal w/ it???????
Thank's Much :helpsmilie:
99SilverSE
Year and Trim: Loaded 2005 GP GTP
Re: Intense pcm reflashing's
Post by 99SilverSE »
It's supposed to firm your shifts some, But have them check it out because somehow my PCM got the wrong gear ratio. Mine started whining and just acting funny sometimes like it didin't know when to shift. (I thought my tranny was going and almost got it rebuilt) But when I got it scanned at Autozone and also at the trans place it came up "Incorrect Gear Ratio" ofcoarse the tranny place said cause it's slipping.
Anyway..
I didn't get it fixed till almost a year later and works great now. I think that someone changed the PCM(before I bought the car) and put one in from a car with a diff gear ratio but, It wasn't noticeable untill the PCM tune.
Almost 79k miles
Mods....
Homemade FWI
Autolite 606 plugs, Autolite wires, new PVC and APC cone filter at 66k miles
mylittleblackbird
Year and Trim: 1995 LX(went to the shredder)*sniffle*
1999 SE
Post by mylittleblackbird »
My car(99 SE) firms up the shifts when the trans gets on the warm side. So much so that I'd almost swore the first time I experienced it that the EPC went bad. No such luck, was just tuned to behave that way. I'd never got it warmed up enough to experience it previously was all. Though I would say it was a bit harsh with the engine mounts being soft, I haven't had it warm enough to repeat.
One way to look at it is this. Less slip between shifts, less heat. I don't know how much difference it actually makes though. Perhaps someone else has that information.
The car came from the previous owner with an Intense PCM that I haven't molested yet.
Last edited by mylittleblackbird on Mon Jul 27, 2009 9:39 am, edited 1 time in total.
I have a Bonneville, it's white and N/A! :twisted:
Mod List: Hood and Fender "adjustment" - "Enhanced" A/C compressor clutch - Extra loud PS Pump - Mega sensitive CKPS - Audible Rear Drums - Lowered headliner - Custom stained upholstery - "Brown Devil" weight reduction kit - Low Friction Belt. More to come!
LeSabre in Buffalo
Year and Trim: 2012 Eco
Post by LeSabre in Buffalo »
Mine slams when I re-start and go quickly. Otherwise it just shifts normally under light throttle. WOT is enough to get some jerky shifts, and my car hates being warm. Shifts go to heck when the transmission is above 170* F. But it shifts really nicely at ~165* F.
J. Baker
Post by J. Baker »
ok guys i'll go to autozone tom. but as 4 the tranny i no it's good it's never acted like this b4... i got the pcm re flashed and then it started!!!! and i'm not the type to beat on my car 4real i've been nice ever since i had the work done... thank you so much 4 the help i'll get back to u asap with an up date :beerchug:
willwren
Post by willwren »
Please be aware that if you try very hard not to text message us on this forum, you'll get better responses to your posts.
viewtopic.php?f=2&t=14
