Bogging Down Briefly
CincyGXP
- Year and Trim: 2004 Bonneville GXP
98 SE
Olds Aurora Final 500 - Location: Cincinnati, Ohio
98 SE, 104000 miles, has bogged down twice in the past 4 days. Once on deceleration, once on acceleration. Doesn't stall, but check gages lights flash and bells ding. Then continues to run fine. Also, today, noticed a metallic clanging coming from under the car when accelerating up hills. Stops as soon as you let off the gas. Any ideas? Igniton problem on the bogging down? Not sure how old plugs/wires/coils are, but I got the car from my Dad when he died. It had about 92000 when I got it from him, and he got it about 78,000 miles, and he never changed them. Not sure about previous owners.
Thanks
Thanks
- JMH1950
- Posts like an L36
- Year and Trim: no longer a Bonneville owner
Re: Bogging Down Briefly
That sounds exactly like what mine was doing for awhile. Drove me nuts trying to track it down. It wouldn't set a code most times and when it did, it wouldn't set the same code twice in a row.
Turned out to be a bad PCM. Glad I had a spare to try.
2001 F150 a basic six cyl with 5 speed manual trans.wjcollier07 wrote:Darn it John...now you got me thinking mine's not big enough.
'66 Piper Cherokee 360 CID , 180 hp, 155 mph @ 2500 rpm, drop in K&N filter.
CincyGXP
98 SE
Yea, it's not throwing a code, unless it's stored. It's running awesome, except for the two times it bogged down.
- Echo SSEI
- Retired Gearhead
- Year and Trim: 1997 SSEi
1993 SSE - Location: Phoenix, Arizona WCBF '05, '06, '07, '08 - NEBF '07
Make sure your battery terminal connections are clean, tight, and secure. Loose or corroded connections have been known to result in stalling/bogging issues. A general tune-up may also be in order, but cleaning and tightening the battery cables is a free check.
"Really Not Stock Anymore" Bob and most recently renamed, "Chief BadLifter"
Best ¼ ET=13.674, Best 60’=2.122, Best Trap=102.26 mph Pacesetter headers (2.5" outlet), Magnaflow hi-flo cat, INTENSE FWI w/K&N 9" cone, ZZP XP cam, INTENSE OR pushrods, Comp 105 springs, Autolite 103 plugs, Stoppenbach tuned PCM
SingsCountry1967 wrote:I can babysit your car for the week... or rent it.... I won't race it I swear <fingers crossed>
GXP_vince
- Posts like a Northstar
- Year and Trim: WCBF 2008 Survivor
Check your alternator wires also. I recently ran into something like that.
f1.4 and be there ----> http://www.fallbrookstudios.com
95 Black Bonneville SLE Supercharged / 95 Green SE, Daily Driver / 95 Black BMW 740iL / 06 Jeep Wrangler 3 inch lift 33in Tires / 2005 Tricoat GXP 32k / 2004 GXP *in car heaven*.
CincyGXP
98 SE
Battery cables clean, alternator wires ok. Now it has stalled a couple of times, but started back up. Crankshaft sensors?
CincyGXP
98 SE
Got my front brakes replaced on the GXP today and was talking to my mechanic about the stalling/starting right back up on my 98 SE. He said in his experience, this is usually caused by a problem with the IAC. Can I clean this part up, or does it have to be replaced? Also, where is this located on the 98? Thanks for any help.....
wjcollier07
- Year and Trim: ____
IAC should be under the TB, but I don't see how this would make any difference in power..as that merely regulates idle speed/closed throttle plate position.
My 98 SE was doing that for the short time I had it...ended up cleaning up the coils, ICM, plugs and wires and it stopped all its bickering it had with idling and with high load situations. It only was around 88k at the time, but still had all original wires and plugs.
Any sensor problems would more than likely throw a code. This sounds like an ignition problem to me, especially if its starting right back up...
If its got 104k, and by any chance you're on original plugs and wires, this is definitely about the time that crap would start rearing its ugly head. Original wires, old plugs and original oxygen sensor just got changed on my 93 at 105k and apparently made a few WORLDS of difference with general drivability and compliance with everything else being up to date.
If that doesn't fix your issues, check your fuel pressure. Could be a faulty FPR not holding the rail pressure, or causing intermittent pressure drops. Simple and cheap fix there.
John
CincyGXP
98 SE
Thanks for the replies, will try all one by one. Does anybody have a pic of exactly where the IAC is?
CincyGXP
98 SE
Took the car to Autozone and had it scanned (it finally threw a code). PO122, tps. They want $45 out the door for a new one. Any idea what size those bolts are that hold it on? Looks like a hex or allen wrench is required, but could you use something else in pinch?
I'm surprised John didn't post this, but make sure this list is up-to-date. If ignored, these things can cause strange issues.
Brand Suggestions are in the parentheses.
- 1987-2005 Bonneville / Buick 3800 Maintenance List
Run Seafoam through gasoline and intake every 5,000 miles. One pint of Seafoam in a half tank of fuel is a good mix. The intake is optional, but recommended.
Grease: Ball Joints, Tie Rods Every 8-10k ( recommended) [b]Air Filter[/b] [i]Every 15k[/i] [s ... Amsoil EaA, Purolator PureONE)[/size]
PCV Valve Every 30k
Fuel Filter Every 15-25k (Purolator, AC Delco, WIX)
Spark Plugs Every 30-50k (NGK TR55 or Autolite 605) (Never Bosch)
Oil & Filter Every 5-6k or Every 6 months (Mobil1 or Amsoil)(Mobil1, Purolator PureONE, Amsoil EaO or WIX) (Never Fram) viewtopic.php?f=45&t=214
*Conventional Oil Every 3k/3 months(Pennzoil with a WIX (Napa), Delco or Purolator filter)
Transmission Flush Every 15-20k (Always make sure filter is changed when flushed)
Cooling System Flush Every 25-50k or Annually (Peak or Prestone Green Coolant Only) (Never Dexcool)
Cabin Air Filter Inspect and Replace every 15k, or as needed in dusty conditions. (Note: 00+ Only)
*Special Considerations*
All 3800s, LG3, LN3, L27, L36, L26, L67 & L32, especially important on vehicles factory installed with orange Havoline Dexcool Antifreeze/Coolant: http://www.dex-cool.net/
Supercharger Belt (Series II and III only); Inspect Every 15k, Replace Every 100k or as needed.
Rev. 6/7/09 By 00Beast
CincyGXP
98 SE
Ok, after a thorough cleaning of the IAC and MAF sensor, the stalling has stopped. The IAC was really gunked up and the MAF was pretty dirty too. Just posting this in case anyone else has a stalling issue......
LeSabre in Buffalo
- Year and Trim: 2012 Eco
Might want to clean your throttle body also. If the IAC and MAF were as bad as you said, the throttle body must be in need of cleaning too.
CincyGXP
98 SE
He actually did clean the throttle body. It has stalled twice since he cleaned everything. He said even though he cleaned it, it could still be bad, (IAC valve). Does anybody else think this could be the Crankshaft Sensor? Sounds like the classic symptoms (stalling, starting right back up)?
CincyGXP
98 SE
Just an update: car threw a code the other day. Throttle Position Sensor and Crankshaft Position Sensor. Had both replaced, and car is running great with no stalling issues. Hope this helps somebody in the future.
- spoiledred94
I think it will be a big help to me when I get back down to my 94 SE that is having that same set of problems. Great you figured it out!
great car. Wrecked
Burnt Bonny.
great car. Wrecked
Burnt Bonny.
LeSabre in Buffalo
Glad to hear that's what it was!
