'00 SSEi - Replacing coils
David CO
Post by David CO »
It looks like I will be replacing my ignition coils in my '00 SSEi.
I can do a few things o n this car mechanically but am by no means a mechanic. Is there anything I need to know concerning replacing these coils.
To reference the issues: Hard shudder in the car upon 1/3 to 1/2 of throttle. MAF has been replaced w/ new as has TPS. Still a lack of acceleration and power. Codes pulled say MAF (still) and normally show a misfire in #4, sometimes #1 and #6 but mainly #4. It seems to be a load issue as I can have it in park and go TWO and no issue. Only upon harder acceleration.
Thanks in advance
Re: '00 SSEi - Replacing coils
Before you replace the coils, make sure they're bad.
Techinfo is your friend: viewtopic.php?f=48&t=1683
Pontiacdad
Post by Pontiacdad »
Yes, first test the coils, they are probably ok.
Even new wires can cause the issues your describing, check them too.
When was the last time you changed the plugs?
Bone Evil
Mods: Tog Headers, cat delete, Al 104's gapped .050, 1.9 rockers, 105 springs,
Intense FWI, DHP Power Programmer PCM, Intense tranny with gen2 lsd,
Aeroforce scan gauge, Clear front and back, N* TB & LQ4 Maf,
Hoosier slicks, ZillaMotorsports P/P GenV & LIM
Pisco_Paul wrote:Every time you pat my head, you pat a piece of my valve retainers.
Check the wires for resistance with an Ohm meter, and make sure they all read the same, that there's not one that reads way higher than the rest. If it does, take them back, or throw them out, depending on age. I highly recommend Beldin Premium wires from NAPA, they have a lifetime warranty, and are of good quality, if they're old or bad. Also, you never stated what you have done for maintenance, so just make sure this list is up to date, especially your spark plugs.
Brand Suggestions are in the parentheses.
  • 1987-2005 Bonneville / Buick 3800 Maintenance List
    Run Seafoam through gasoline and intake every 5,000 miles. One pint of Seafoam in a half tank of fuel is a good mix. The intake is optional, but recommended.
    Grease: Ball Joints, Tie Rods Every 8-10k ( Green Grease recommended)
    PCV Valve Every 30k
    Fuel Filter Every 15-25k (Purolator, AC Delco, WIX)
    Spark Plugs Every 30-50k (NGK TR55 or Autolite 605) (Never Bosch)
    Oil & Filter Every 5-6k or Every 6 months (Mobil1 or Amsoil)(Mobil1, Purolator PureONE, Amsoil EaO or WIX) (Never Fram) viewtopic.php?f=45&t=214
    *Conventional Oil Every 3k/3 months(Pennzoil with a WIX (Napa), Delco or Purolator filter)
    Transmission Flush Every 15-20k (Always make sure filter is changed when flushed)
    Cooling System Flush Every 25-50k or 3-5 Years (Peak or Prestone Green Coolant Only) (Never Dexcool)
    Cabin Air Filter Inspect and Replace every 15k, or as needed in dusty conditions. (Note: 00+ Only)
    *Special Considerations*
    All 3800s, LG3, LN3, L27, L36, L26, L67 & L32, especially important on vehicles factory installed with orange Havoline Dexcool Antifreeze/Coolant: http://www.dex-cool.net/
    Supercharger Belt (Series II and III only); Inspect Every 15k, Replace Every 100k or as needed.
    Rev. 7/19/09 By 00Beast
Archon
Post by Archon »
Is it worse when the car warms up, but seems to be better when cold?
