2000 - 2005 SSEi, SLE, SE Body and Acessory codes (non GXP) http://www.pontiacbonnevilleclub.com/forum/other/topic8894.html |
Page 1 of 1 |
Author: | myfirstbonnie [ Tue Jan 27, 2009 2:44 pm ] |
Post subject: | 2000 - 2005 SSEi, SLE, SE Body and Acessory codes (non GXP) |
Data Link Communications U1000, U1255 Class 2 Communication Malfunction U1001, U1254 Loss of XXX Communications U1300 Class 2 Data Link Low U1301 Class 2 Data Link High U1305 Class 2 Data Link Low or High Lighting Systems B2556 Interior Lamp Rheostat Circuit Range B2627 Pass Compartment Dimming Circuit #2 Low B2628 Pass Compartment Dimming Circuit #2 Low B2641 Delayed Exterior Lighting Control Circuit Range B2642 Delayed Exterior Lighting Control Circuit Low B2643 Delayed Exterior Lighting Control Circuit High B2646 Ambient Light Sensor Circuit Range B2647 Ambient Light Sensor Circuit Low B2648 Ambient Light Sensor Circuit High B2657 Ignition Halo Lamp Output Circuit Malfunction Entertainment B1001 Option Configuration Error B1780 Theft Lock Enabled B2810 Steering Wheel Control Enertainment Circuit Malfunction Cellular Communication B2462 GPS Signal Error B2476 Cellular Phone Select Service Switch Malfunction U1500 Inter-Device Dedicated Bus Malfunction Body Control System B1000 ECU Malfunction B1004 Keep Alive Memory (KEM) B1007 EEPROM Write Error B1009 EEPROM Checksum Error B1010 Calibration ROM Checksum Error B1390 Device Voltage Reference Input Circuit Malfunction B1422 Device Power Moding Malfunction Instrument Panel, Gauges, and Console B2823 Trip Odometer Reset Switch Circuit Low B2838 DIC Reset Switch Circuit Low B2843 DIC English / Metric Switch Circuit Low B3564 DIC Mode Switch Circuit Low B3569 DIC Select Switch Circuit Low Theft Deterrent B2734 Coded Key Controller Memory Failure B2947 Antenna Power Short to Ground B2948 Antenna Power Short to Battery B2955 Key Code Input Sort to Battery or Open B2960 Invalid Coded Key Present B3031 Key Decoder Device in Assembly Learn Mode B3055 Key Not Present Doors B1562 Mirror Right Control Switch Circuit Low B1567 Mirror Left Control Switch Circuit Low B1572 Mirror Up Control Switch Circuit Low B1577 Mirror Down Control Switch Circuit Low B1582 LH Mirror Horizontal Position Sensor Circuit Low B1583 LH Mirror Horizontal Position Sensor Circuit High B1592 LH Mirror Vertical Position Sensor Circuit Low B1593 LH Mirror Vertical Position Sensor Circuit High B1612 RH Mirror Horizontal Position Sensor Circuit Low B1613 RH Mirror Horizontal Position Sensor Circuit High B1622 RH Mirror Vertical Position Sensor Circuit Low B1623 RH Mirror Vertical Position Sensor Circuit High B3142 LF Unlock Switch Circuit Low B3147 Passenger Unlock Switch Circuit Low B3152 LF Lock Switch Circuit Low B3157 Passenger Lock Switch Circuit Low B3172 RF Window Up Switch Circuit Low B3177 RF Window Down Switch Circuit Low B3182 LR Window Up Switch Circuit Low B3187 LR Window Down Switch Circuit Low B3192 RR Window Up Switch Circuit Low B3197 RR Window Down Switch Circuit Low B3377 LF Window Up Switch Circuit Low B3382 LF Window Down Switch Circuit Low B3387 RF Window Up Switch Circuit Low B3392 RF Window Down Switch Circuit Low B3397 LR Window Up Switch Circuit Low B3452 LR Window Down Switch Circuit Low B3457 RR Window Up Switch Circuit Low B3462 RR Window Down Switch Circuit Low B3467 LF Window Express Down Circuit Low B3472 RF Window Express Down Circuit Low B3527 Window Lockout Switch Circuit Low U1161 Loss of PDM Serial Data U1162 Loss of LRDM Serial Data U1163 Loss of RRDM Serial Data U1170 Loss of Driver Door Switch Assembly Serial Data Seats B1735 Driver Seat Front Up Switch Circuit Malfunction B1740 Driver Seat Front Down Switch Circuit Malfunction B1745 Driver Seat Rear Up Switch Circuit Malfunction B1750 Driver Seat Rear Down Switch Circuit Malfunction B1755 Driver Seat Assembly Forward Switch Circuit Malfunction B1760 Driver Seat Assembly Rearward Switch Circuit Malfunction B1815 Driver Recline Forward Switch Circuit Malfunction B1820 Driver Recline Rearward Switch Circuit Malfunction B1825 Driver Recline Sensor Circuit Malfunction B1826 Driver Recline Sensor Circuit Performance B1830 Driver Lumbar Forward Switch Circuit Malfunction B1835 Driver Lumbar Rearward Switch Circuit Malfunction B1840 Driver Lumbar Up Switch Circuit Malfunction B1845 Driver Lumbar Down Switch Circuit Malfunction B1850 Driver Lumbar Horizontal Sensor Circuit Malfunction B1851 LF Lumbar Horizontal Sensor Circuit Performance B1860 Driver Lumbar Vertical Sensor Circuit Performance B2355 Driver Front Vertical Sensor Malfunction B2356 Driver Front Vertical Sensor Performance B2365 Driver Rear Vertical Sensor Malfunction B2366 Driver Rear Vertical Sensor Performance B2375 Driver Seat Assembly Horizontal Sensor Circuit Malfunction B2376 Driver Seat Horizontal Sensor Performance B2757 Driver Memory 1 Select Switch Circuit Low B2762 Driver Memory 2 Select Switch Circuit Low B2772 Driver Memory Exit Switch Circuit Low |
