Broken rear ball joint http://www.pontiacbonnevilleclub.com/forum/1992/topic29152.html |
Page 1 of 1 |
Author: | ChilinMichael [ Sun Nov 06, 2011 6:02 pm ] |
Post subject: | Broken rear ball joint |
Well, About a mile from my house thankfully, while driving I hear a loud "bang" and then grinding from the rear, sure enough (to me) looks like the rear balljoint popped out. Control arm is hanging down into the wheel. Pics below. Need to know how I go about fixing this and how hard. Mind you I have to move out of here in 3 weeks and have very limited time. |
Author: | Jrs3800 [ Mon Nov 07, 2011 12:02 pm ] |
Post subject: | Re: Broken rear ball joint |
You will need to raise the lower control arm with a floor jack, Might want to have another under the rear portion of the car as well.... Once you raise the lower control arm, you will need to remove the wheel, depending on what you have in the way it may or may not be easy to remove the upper part of the ball joint... As for the lower control arm, the remainder of the ball joint will have to be pressed out( either a ball joint removal kit or a press ) and the new one pressed in... From there you would be able to reassemble... When I go through the 95, it will get new ball joints all the way around... |
Author: | harofreak00 [ Mon Nov 07, 2011 12:37 pm ] |
Looks familiar... I had to fix mine in a Cub Foods parking lot. I replaced the entire control with one I had on the shelf. Way easier than worrying out pressing the ball joint in and out, especially in a foreign area. http://www.pontiacbonnevilleclub.com/fo ... 27&start=0 |
Author: | ChilinMichael [ Mon Nov 07, 2011 2:12 pm ] |
Luckily the car was close to home and the tow truck driver was very careful and good about towing it...backed it right into my garage so I have a very decent place to work on it. |
Author: | crash93ssei [ Mon Nov 07, 2011 2:45 pm ] |
Also same on my old 93 last year. I think there is a c-clip that holds the ball joint in as well that must be removed before pressing it out. viewtopic.php?f=19&t=17897&hilit=ball |
Author: | rustyroger [ Tue Nov 08, 2011 4:58 am ] |
Just a thought, do the ball joints have a grease point?. Getting busy with a grease gun is an often neglected part of routine maintenance, most in and out lube shops won't do it as it takes too much time. Way back in the '70s the British Morris Marina had a terrible reputation for the front suspension collapsing. I repaired a lot of them, as did many other repair shops in the day. Nearly always they had failed because the trunnions hadn't been greased, including some that had a full dealer service history. Don't let that happen to you!. Roger. |
Author: | ChilinMichael [ Tue Nov 08, 2011 10:14 am ] |
Thanks Roger, and I think they do have a grease fitting. |
Author: | reb [ Tue Nov 08, 2011 11:07 am ] |
Front and rears have grease fittings. |
Author: | 00Beast [ Tue Nov 08, 2011 11:29 am ] |
Unfortunately, neither of these failures appear to be from lack of grease. This one the whole joint came out of the control arm, not just the ball coming out of the socket, where your lube goes. It is important to remember to grease any and all fittings however. Unfortunately, very few cars anymore come with grease-able parts anymore. Our 02 Suburban had 11 fittings, our '11 Suburban has 2.... |
Author: | Jrs3800 [ Tue Nov 08, 2011 2:43 pm ] |
Its just simple wear... 16 years and close to 200K will do that...lol |
