It is currently Sun Oct 12, 2025 12:00 am
Post new topic Reply to topic  [ 2 posts ]
PostPosted: Fri Jun 16, 2017 3:48 pm
Year and Trim: 2004 Buick Lesabre Limited
Gran Touring package
I have a 2004 H-body Lesabre(similar to Bonneville), with 90k miles. I have had a shift kit on it for the last couple years which made a huge difference in the 4T65E slow shifting, but it is still a little slow and would benefit from a slight bump in line pressure. How do I go about changing line pressure? Is HPtuners the only option? Would any shops out there be able to do it or have the software?
My transmission also has the slip then catch problem when suddenly going from no throttle to gassing it from a stop. It's not too bad right now but if I give it a sudden ton of throttle from a stop it will do it. Would turning up the line pressure help with the slip/catch issue?
Thanks
PS. I'm in CT so if anyone in the Northeast US can tune it let me know
PostPosted: Sat Jun 17, 2017 7:36 pm
Year and Trim: 2000 SSEI
you can adjust the pressure in the ECU with HPTuners or DHP Powertuner or the other option is to get like a ZZP or a Transgo shift improver kit (Mechanical shift kit rather then a Electronic)
https://zzperformance.com/3800/4t65e-shift-kit.html
S
Shane "RedZMonte"
2004 Z16 Z06: Virgin
There are no new unread posts for this topic. PCM Trans Shift Pressure tables
Allmachtige
Sun Apr 19, 2009 11:36 pm
Allmachtige View the latest post
There are no new unread posts for this topic. GOT BELT SLIP ?
rrounds
23
4231
Mon Dec 01, 2008 4:57 pm
willwren View the latest post
There are no new unread posts for this topic. Limited slip differentials
1fatcat
11
2074
Thu Jun 17, 2010 2:55 pm
95naSTA View the latest post
There are no new unread posts for this topic. Amazing... Its my turn getting excited.
[ Go to pageGo to page: 1, 2, 3 ]
PDXGTP
50
4509
Wed Mar 18, 2009 11:33 am
SuperSLE View the latest post
There are no new unread posts for this topic. Gen V vacuum line ?
Pair of SSEI
Wed Mar 16, 2016 6:54 pm
Pair of SSEI View the latest post
Users browsing this forum: Google [Bot] and 8 guests
