It is currently Sat Oct 11, 2025 11:45 pm
Post new topic Reply to topic  [ 5 posts ]
PostPosted: Tue Oct 26, 2010 3:52 pm
Year and Trim: 1996 Bonneville SSEI
Hey guys im new to this forum, i just recently picked up a 1996 Bonneville SSEI with just over a 100 000 miles on it. It is my secondary vehicle and make trips of about 1200 km a week. I like the performance of the car and can do lots of work myself but i am also looking to get good mpg. I have a cone filter on the car already, what else is available to increase mpg and performance? also this car was owned by an elderly couple and is in great shape. I am looking at also giving it a complete tune up. I have changed the oil/filter, fuel filter, plugs, new cone filter, what else can i do for a complete tune up? egr clean?? Any advice to help performance and mpg in this car would be greatly appreciated! thanks in advance!
PostPosted: Tue Oct 26, 2010 4:09 pm
    1987-2005 Bonneville / Buick 3800 Maintenance List
    Run Seafoam through gasoline and intake every 5,000 miles. One pint of Seafoam in a half tank of fuel is a good mix. The intake is optional, but recommended.
    Grease: Ball Joints, Tie Rods Every 8-10k ( Green Grease recommended)
    PCV Valve Every 30k
    Fuel Filter Every 15-25k (Purolator, AC Delco, WIX)
    Spark Plugs Every 30-50k (NGK TR55 or Autolite 605) (Never Bosch)
    Oil & Filter Every 5-6k or Every 6 months (Mobil1 or Amsoil)(Mobil1, Purolator PureONE, Amsoil EaO or WIX) (Never Fram) viewtopic.php?f=45&t=214
    *Conventional Oil Every 3k/3 months(Pennzoil with a WIX (Napa), Delco or Purolator filter)
    Transmission Flush or Pan Drop Every 15-20k (Always make sure filter is changed when flushed) http://www.pontiacbonnevilleclub.com/fo ... 45&t=10193
    Cooling System Flush Every 25-50k or 3-5 Years (Peak or Prestone Green Coolant Only) (Never Dexcool)
    Cabin Air Filter Inspect and Replace every 15k, or as needed in dusty conditions. (Note: 00+ Only)
    *Special Considerations*
    All 3800s, LG3, LN3, L27, L36, L26, L67 & L32, especially important on vehicles factory installed with orange Havoline Dexcool Antifreeze/Coolant: http://www.dex-cool.net/
10/26/2010 by 00Beast
PostPosted: Tue Oct 26, 2010 4:14 pm
Your cone filter may actually be hurting you, depending on how you installed it. Let's see your setup for starters, then we'll take a look at your other options.
PostPosted: Tue Oct 26, 2010 4:43 pm
Why never bosch? i just purchased bosch platinum plus but havent installed them yet? the cone filter it set up on the end of the short intake tube from the stock airbox. since installed i have noticed an increase of performance and the mileage seems to have improved with regular driving
PostPosted: Tue Oct 26, 2010 5:06 pm
Platinum plugs are the absolute worst to run on a supercharged app. They will act like a glow plug and can cause damage. Use copper plugs.
What brand of filter is it? With that setup you want to either make a box around it to seal it from engine air, or extend it so the filter is located outside of the engine bay. If not, you're pulling in hotter air than the stock box, and gonna hurt performance.
There are no new unread posts for this topic. Advice for performance mods
rique8405
Mon Apr 13, 2009 8:07 pm
There are no new unread posts for this topic. performance mod ?
ssei Racer
Fri Apr 02, 2010 8:26 am
willwren View the latest post
There are no new unread posts for this topic. More Performance
xcdude600
Sun Apr 22, 2012 3:46 pm
01bonneSC View the latest post
There are no new unread posts for this topic. 95 L67 Performance
flatlander745
Fri Feb 25, 2011 12:41 am
flatlander745 View the latest post
There are no new unread posts for this topic. JMB Performance FWI
wingman
Thu Jan 22, 2009 11:40 pm
wingman View the latest post
Users browsing this forum: No registered users and 9 guests
