It is currently Tue Aug 16, 2022 5:31 am
PostPosted: Sun Feb 03, 2013 5:51 pm
My wifes Regal is bogging down when you press on the accelerator pedal, if you back off some it will gradually pick up speed but if you floor it falls flat on its face. My neighbor hooked up the fuel pressure gage, that had a bleed off valve, the pressure was good but he said it would not fill up the container fast enough so he said the volume was not enough. Not sure I believe that, well anyways I changed the fuel filter and its the same. The low coolant light haz been on but radiator is full so I think it need to be cleaned, any chance that could have an effect on the way it runs? I am going to look at the screen on the throttle body too. I am hoping its not the cat. Any other thought?
PostPosted: Sun Feb 03, 2013 5:58 pm
Assuming it isn't throwing any SES codes? That would be my start. Could be anything from a miss to a cat to a MAF sensor or something. Hard to say for sure if there is no code. (Without seeing the car that is)
91 Buick Riviera | S2 L67 swap/4T60E | 124k mi | Antelope Beige Metallic w/Tan Int | Beat-up Beater / Cool Digital Dash
92 Pontiac Bonneville SSE | L67/4T60E | 75K mi | Med Slate Grey w/ Two-Tone Grey Int. | Low Miles Time Capsule / Storage Occupant
92 Chevy Lumina Z34 | LQ1/4T60E | 177k mi | Torch Red w/Grey Int. | Rusty Storage Occupant
03 Buick Park Avenue Ultra | L67/4T65E-HD | 197K | White Diamond Metallic w/Shale Int. | Rust Free Southern Sourced Storage Occupant
99 Chevy Tahoe LT | L31/4L65E | 246k mi | Spiral Grey Metallic w/Grey Int. | Daily Winter Rig / Tow Pig / Portable Concert Hall
04 Cadillac Seville STS | L37/4T80E | 216k mi | Red Jewel Tintcoat w/Shale Int. | Storage Occupant Too
05 Cadillac Deville | LD8/4T80E | 146k mi | Black w/Two Tone Tan Int. | Livery Pkg Daily
James May wrote:
Hello.
PostPosted: Sun Feb 03, 2013 6:32 pm
No codes, feels like its starving for gas or something constricting. Thank you sir
PostPosted: Sun Feb 03, 2013 7:21 pm
Well, cleaned up the low coolant sensor which shut off the dash light. Now I can take the 48 dollar one back to Autozone. I don't have a thing to clean the mass air flow sensor, but I doubt that is the problem. Too old to lay under the car and too cold also. I need a bigger garage and a lift.
PostPosted: Sun Feb 03, 2013 8:13 pm
If I was closer to Morris I'd come check it out. Sorry I can't help more at the moment.
James May wrote:
Hello.
PostPosted: Sun Feb 03, 2013 10:08 pm
Thanks for the offer, I checked furl pressure myself and it showed 46# running and around the same when I turned the key to on but dropped to 42#, seems a little weak. When I disconnected the vacuum hose going to the fuel pressure regulator the pressure went to 60# so I plugged the line and took it for a ride, same thing. If it were the cat, wouldn't it smell hot? Beginning to think the intake manifold is leaking vacuum.
PostPosted: Tue Feb 05, 2013 5:00 pm
It was the cat. 228.00 installed, still money for mods
PostPosted: Tue Feb 05, 2013 5:02 pm
Not a bad deal. Glad to hear it's fixed.
James May wrote:
Hello.
There are no new unread posts for this topic. 2002 Buick Regal
deano55
Sat Mar 03, 2012 6:12 pm
deano55 View the latest post
deano55
Mon Aug 02, 2021 9:16 am
Sirius View the latest post
There are no new unread posts for this topic. 02 regal console
deano55
Fri Dec 16, 2016 9:22 pm
There are no new unread posts for this topic. 02 Buick Regal
deano55
Wed May 01, 2019 10:50 pm
There are no new unread posts for this topic. 1999 Regal P1860
BoiseGTP
Mon Apr 07, 2014 8:42 pm
BillBoost37 View the latest post
cron
