It is currently Fri Apr 10, 2020 8:58 am
PostPosted: Mon Dec 18, 2017 4:59 pm
Year and Trim: 2001 Pontiac Bonneville SSEi
Title states it. I need to remove my heads up display switch because I think there’s a bad connection to the intensity text after the light was dim the other day, now off
PostPosted: Tue Dec 19, 2017 3:13 pm
Year and Trim: 2005 Bonneville SLE
I don't have a HUD so i dont know for sure, but if I remember correctly, you will need to take off the dash bezel. This is the big piece of plastic that wraps around your gauges and extends down to the HVAC controls.
There are two push clips above the instrument cluster, so you will need to take something thin and press right in the middle until it pops off. Then gently pry around the edges until it pulls off, but be careful since there are sharp parts on the inside that can scrape the paint off the buttons on your radio/HVAC. Since you have an SSEi, you will need to unplug the DIC buttons in order to get it to come out farther. Since the HUD switch sits in the bezel itself, you will need to just reach around the back of the bezel to unplug it. Then you will need to take the bezel out of the car since it will make it much easier to unscrew the switch with more room. Then it should be out, and once you're done doing the repair, follow the instructions backwards to reassemble.
2005 Pontiac Bonneville SLE in Crimson Tintcoat.
TransGo Shift Kit, Haro's Boat roller mount, new Monroe air shocks.
Previously...
2003 Pontiac Grand Am SE1 3.4L sedan.
- Nicer rim and tire swap, leather swap, Aux stock radio swap, rear disc brake swap.
PostPosted: Tue Dec 19, 2017 6:55 pm
Pretty sure the HUD switch just pops out with some prying. Use a plastic pry tool or a flat screwdriver wrapped in electrical tape to avoid damaging the trim.
PostPosted: Tue Dec 19, 2017 7:21 pm
The switch is not the problem. The ground inside the projector for the light dimming sensor is bad......there is a post for a fix.....
2000 SSEi - SilverBullet - 78,000 kms, 4" "straight shot" custom headlight ram air inlet, TOGs, 1.9's, Lsd, 2.9-3.4"MPS 10-15 psi, Ported GenV, EGR eliminated, OR pushrods, oil volume kit, trani cooler & shift kit, Titanium retainers, 90 lb springs, 160 Stat, 42# injectors, Fuel pump voltage increase, Wideband O2, 3" to dual 2 1/2" Magnaflows, Snow Meth/water injection, after SC temp gauge, 255/50WR17, timing commander set 15-18*@WOT, 2 speed Fan over-ride, disabled DRL, Solid motor mount, Meziere Electric water pump, adjustable fuel pressure regulator, Drilled & slotted rotors/ceramics, GXP sway bars and STB, Upgraded and rebuilt transmission, Pioneer Bluetooth stereo with sub and 800 W amps, PB 13.5 quarter, (April 2014 car of the month)
PostPosted: Tue Dec 19, 2017 10:55 pm
What’s the title of the post?
PostPosted: Wed Dec 20, 2017 11:33 am
Ok, I'll Play...
Thread title;
Quote:
Heads up display SWITCH removal
Answer #1 which is more involved and will do it the "technical" way;
Answer #2 from Ed above (00Beast), which is more of the quick/easy way;
What am I missing here? GM interiors of the 90's and early 2000's were designed and made in partnership with Little Tikes and the parts *generally* snap in/out with a little prying.
PostPosted: Wed Dec 20, 2017 1:51 pm
Well I tried with a little flat blade and it was moving around but I’m not sure if there are clips around that I need to look for while I’m prying the switch gingerly and I believe I forgot to mention the image button still lights up so I think instead of a connection being bad that there are burned out bulbs
There are no new unread posts for this topic. Other cars with Heads Up Display
Krenzy
19
1819
Wed Mar 21, 2012 1:17 am
BonneMe View the latest post
There are no new unread posts for this topic. 36 vs 67 heads
01bonneSC
Sat Mar 20, 2010 8:25 am
There are no new unread posts for this topic. heads up
corinne
Tue May 27, 2008 12:07 pm
Custom88 View the latest post
There are no new unread posts for this topic. LIM gasket job on the '99, (Heads up for FEL PRO GASKETS)
99bonnieSE
Tue Nov 08, 2011 8:50 pm
crzydmnd72 View the latest post
There are no new unread posts for this topic. 97 heater display not working
christinewormley
Fri Dec 02, 2016 12:47 am
SATADrive420 View the latest post
